Getting text with format
Ceprotec
Post by Ceprotec »
I am using the filll fields function with getvaluefromdatabase, where i'm getting a formated (bold,italic, etc..) text, and i want to put this text into a variable to the function insert ( or replace ), and still get the formated text.
Could anyone help me with this ?
Sorry, I do not understand the question.
I suppose the function getvaluefromdatabase is a function from one of demo projects?
Ceprotec
Post by Ceprotec »
Yes, it is.
I'm trying to replace a text and bring the text with the format style that i save from other text file...
The fillfields function replace letter per letter, I want to replace the entire word/text, the text that i want to overwrite comes from another text file from the database
Answered in a private message.
tiagosis
Re: Getting text with format
Post by tiagosis »
Hello, I would like to know what was the solution applied in this post, because I have similar problem.
Do you store text in format that contains font properties (such as RVF or RTF)?
If not, how do you want to define font of inserted text?
tiagosis
Post by tiagosis »
Yes, I have text in rtf format and would like to replace with a variable contained in a srichviewedit
