Hi
I would like to same the content of a TRichview (Text, CSS, Image) in only one html files, all inline.
Does it's possible ?
When I use SaveHTMLToStream I have linebreak..
Save RichView to Inlinehtml
HTML and CSS are saved in a single file by default.
The problem is only with images, they are saved as separate files by default.
I can suggest the following solutions
1) Use a web archive format (MHT files), containing HTML and images.
MHT files can be opened by browsers like HTML files.
You can find the example in
http://www.trichview.com/forums/viewtopic.php?t=11
(the demo in Delphi\SaveFile folder)
or
2) You can store images just inside <img src>.
The syntax is like this:I.e. the format is: data:[<image type>][;base64],<image data>
Process OnSaveImage2, create the proper value for <img src>, assign it to Location parameter. I think that this feature will be added (as an option) in future versions of TRichView.
or
<img src="data:image/gif;base64,R0lGODlhEAAOALMAAOazToeHh0tLS/7LZv/0j
vb29t/f3//Ub//ge8WSLf/rhf/3kdbW1mxsbP//mf///yH5BAAAAAAALAAAAAAQAA4AAA
Re8L1Ekyky67QZ1hLnjM5UUde0ECwLJoExKcppV0aCcGCmTIHEIUEqjgaORCMxIC6e0Cc
guWw6aFjsVMkkIr7g77ZKPJjPZqIyd7sJAgVGoEGv2xsBxqNgYPj/gAwXEQA7">
