[Example] Does document contain an image
The function HasImage (below) returns True if the given TRichView has an image.
It checks:
- document's background bitmap
- images
- images from image lists
- list markers displaying images
- table background images
- table cells background images
Images are checked in the main document, table cells, notes.
function RVDataHasImage(RVData: TCustomRVData): Boolean;
  i,r,c: Integer;
  ListNo, LevelNo, StartFrom: Integer;
  UseStartFrom: Boolean;
  Table: TRVTableItemInfo;
  ListLevels: TRVListLevelCollection;
  Result := True;
    case RVData.GetItemStyle(i) of
      rvsPicture, rvsHotPicture, rvsBullet, rvsHotspot:
      rvsListMarker:
          RVData.GetListMarkerInfo(i, ListNo, LevelNo, StartFrom, UseStartFrom);
          if (ListNo<0) then
            continue;
          ListLevels := RVData.GetRVStyle.ListStyles[ListNo].Levels;
          if LevelNo>=ListLevels.Count then
            LevelNo := ListLevels.Count-1;
          if (LevelNo<0) then
            continue;
          if ListLevels[LevelNo].ListType in [rvlstPicture, rvlstImageList, rvlstImageListCounter] then
      rvsTable:
          Table := TRVTableItemInfo(RVData.GetItem(i));
          if (Table.BackgroundStyle<>rvbsColor) and (Table.BackgroundImage<>nil) then
          for r := 0 to Table.RowCount - 1 do
            for c := 0 to Table.ColCount - 1 do
              if Table.Cells[r,c]<>nil then
                if (Table.Cells[r,c].BackgroundStyle<>rvbsColor) and
                  (Table.Cells[r,c].BackgroundImage<>nil) then
                if RVDataHasImage(Table.Cells[r,c].GetRVData) then
      rvsFootnote, rvsEndnote, rvsSidenote, rvsTextBox:
        if RVDataHasImage(TCustomRVNoteItemInfo(RVData.GetItem(i)).Document) then
  Result := False;
function HasImage(rv: TCustomRichView): Boolean;
  Result := ((rv.BackgroundStyle<>bsNoBitmap) and not rv.BackgroundBitmap.Empty) or
    RVDataHasImage(rv.RVData);
