ListMarker and rvbdRightToLeft
peke
Post by peke »
numbered list markers do not behave correctly while using rvbdRightToLeft mode. It should use SetTextAlign(.., TA_RTLREADING) in DoPaint method. I've fixed it myself but can you (Sergey) implement it into your source?
What's wrong with markers?
They should be to the right side of the paragraph, if paragraph is RTL.
peke
Post by peke »
LTR:
1.      bla bla
  1.1.  bla bla
RTL, original wrong view:
alb alb    1.
alb alb  1.1.
RTL, original correct view:
alb alb    .1
alb alb  .1.1
As you can see the very last point is reversed.
