RichViewActions, how to get the executing richedit?
SpoQSI
Post by SpoQSI »
in the RichViewActions Demo, which i costumize, i need costum buttons in the toolbar.
Normal OnClick-Events don´t work, as i get exceptions with buttons without any action applied.
Therefor i wanted to create custom Actions, but i don´t know how to access the richview (scalerichview) which is on the executing form.
Here i want to open a Template-RTF which i created.
procedure TsrvActionsResource.OpenPlainTemplateActionExecute(Sender: TObject);
In examples i found this:
procedure TrvActionsResource.rvActionEvent1Execute(Sender: TObject;
  Editor: TCustomRichViewEdit);
var gr: TGraphic;
    Tag: TRVTag;
    Align: TRVVAlign;
    s: TRVAnsiString;
    info: String;
  Editor.GetCurrentPictureInfo(s, gr, Align, Tag);
  info := Format('%s %dx%d', [gr.ClassName, gr.Width, gr.Height]);
  Application.MessageBox(PChar(info), 'Image Info', MB_OK or MB_ICONINFORMATION);
procedure TrvActionsResource.rvActionEvent1Update(Sender: TObject;
var CurStyleNo: Integer;
  CurStyleNo := Editor.CurItemStyle;
  (Sender as TrvActionEvent).Enabled := (CurStyleNo=rvsPicture) or
    (CurStyleNo=rvsHotPicture);
But my Action-Events don´t have the "Editor: TCustomRichViewEdit".
How can i accomplish this?
Greetings, Spo
Simplest way:
Do not create your own action classes. Use TrvActionEvent actions directly, assigning their OnExecute and OnUpdate events. If you want to know how to get TSRichViewEdit from Editor (TCustomRichViewEdit) parameter of these events, let me know.
If you create your own actions inherited from TrvAction, override Execute and UpdateTarget methods. Use GetControl(Target) to get the editor from the Target parameter (where GetControl is a method inherited from TrvAction)
If you create your own actions inherited from TsrvAction, everything is the same, but GetControl returns TSRichViewEdit.
Assigning OnClick of toolbar buttons must work as well.
SpoQSI
Post by SpoQSI »
I don´t understand what i have to do now. in your example in http://www.trichview.com/forums/viewtopic.php?t=4981 you say to use the Action Editor to add a new action. This is what i did. I have:
    OpenPlainTemplateAction: TAction;
    procedure OpenPlainTemplateActionExecute(Sender: TObject);
  private
    { Private declarations }
  public
    { Public declarations }
  srvActionsResource: TsrvActionsResource;
implementation
{$R *.dfm}
  // Here i want to access the RichEdit to load a Template RTF <---------------
If i try to use the OnClick Events of a TToolButton in the MainUnit i get a EListError-Exception in "TCustomrichViewEdit.UpdateAction" where "Result := inherited UpdateAction(Action);".
I cannot reproduce this bug.
I took the ScaleRichView demo in Demos\ActionTest.
I added a new TAction in dmActionsSRV.pas, assigned its OnExecute event. Then I added a button on the toolbar and assigned this action to it.
By the way, you added TAction, not TrvActionEvent like it was explained in the topic.
Please send me a sample project reproducing this bug. Also, tell me which version of Delphi and TRichView you use.
SpoQSI
Post by SpoQSI »
I have no bug assigning an Action to a Toolbutton. The bug, as described, occurs when i do something in the OnClick Event of a Button in the Toolbar.
I have Delphi 6 and the latest Non-Beta TRichView Version.
Please send a sample project (as simple as possible) reproducing this problem to email richviewgmailcom
SpoQSI
Post by SpoQSI »
A sample project is not needed. Open ActionTest (The Demo), add a button to the upper left corner (or somewhere else) on the toolbar and set a Click-Event.
Add this code to the button:
procedure TForm3.Button2Click(Sender: TObject);
var appPath : string;
        appPath := ExtractFilePath(Application.ExeName);
        SRichViewEdit1.RichViewEdit.Clear;
        SRichViewEdit1.RichViewEdit.LoadRTF(appPath + 'TemplateNew.rtf');
And then you get an Exception.
SpoQSI
Post by SpoQSI »
Also, if i try it the TsrvAction-Way you mentioned i cannot compile the code as TCustomRichViewEdit is not know.
Actions cannot work with unformatted editor.
Add
        [color=red]SRichViewEdit1.Format;[/color]
Add RVEdit in uses of this unit.
SpoQSI
Post by SpoQSI »
Great, the two suggestions solved my problems with that. Thank you very much.
One more Question:
How exactly can i get the current Documents RTF-Text as string without saving it to an rtf file?
I need to save and load the documents from and to a Database.
SpoQSI
Post by SpoQSI »
Oh i noticed the problem is not solved completely. When i load an RTF now this way:
procedure TsrvActionsResource.OpenNewPlainTemplateActionEventExecute(
  Sender: TObject; Editor: TCustomRichViewEdit);
        Editor.Clear;
        Editor.LoadRTF(appPath + 'TemplateNew.rtf');
        Editor.Format;
There the RTF Documents Borders/Header/Footer-Preferences arent loaded properly, which results in Header/Footer images and Tables in the Document itself are cut.
As for getting RTF:
function GetRTFString(rv: TCustomRichView): AnsiString;
var Stream: TMemoryStream;
  rv.SaveRTFToStream(Stream, False);
  SetLength(Result, Stream.Size);
  Stream.Position := 0;
  Stream.ReadBuffer(PAnsiChar(Result)^, Length(Result));
  Stream.Free;
As for the error, I do not understand what exactly happens. Can you explain how to reproduce?
SpoQSI
Post by SpoQSI »
Correct:
This is what it should look like and what it looks, if i Load the RTF via the standard open button in the ActionTest-Demo
Incorrect:
This is what it looks like when loaded with this code:
        Editor.Clear;
        Editor.Format;
Well, I understand.
Yes, when you load a document with headers and footers in SRichViewEdit.RichViewEdit, it's not enough to call SRichViewEdit.RichViewEdit.Format, you need to call SRichViewEdit.Format.
Use this procedure:
procedure CompleteFormat(rve: TCustomRichViewEdit);
  Ifc: IRVScaleRichViewInterface;
  Ifc := rve.RVData.GetScaleRichViewInterface;
  if Ifc <> nil then
    Ifc.Format
    rve.FormatAll;
        Editor.Clear;
        [color=red]CompleteFormat(Editor);[/color]
SpoQSI
Post by SpoQSI »
Thank you for the fast response, but i can´t find the unit i have to add to the usings in which CompleteFormat is held.
