about remote desktop ... how much bandwidth is being used?
thanks
antonello
Remote Desktop bandwidth usage
It highly depends on settings.
First, it depends on the screen size and its content, and how often it changes. Unfortunately, RVMedia does not do optimizations like reducing colors or removing a desktop wallpaper.
Next, TRVCamera.FramePerSec
Next, DesktopZoomPercent, if you want to send reduced desktop images
Next, TRVCamSender.Encoding. The recommended values are rvetJPEGChange (for reduced desktop images or complex wallpapers) or rvetPNGChange.
Next, TRVCamSender.FullFrameInterval and FrameDifferenceInterval
You can view traffic using TRVCamTrafficMeter component
thanks!
Sergey Tkachenko wrote:It highly depends on settings.
