Audio only
JimHawkins
Audio only
Post by JimHawkins »
Is it possible to use only audio stream connections (including via the server)?
This is important for us because not all classrooms have webcams.
Yes, of course, you can send only audio information.
If you do not have a camera, just do not activate TRVCamera, and data will be sent only from TRVMicrophone,
Even if you have the both of them, you can control transferring by including/excluding rvmtAudio and rvmtVideo in TRVCamSender.SendMediaTypes and TRVCamReceiver.ReceiveMediaTypes
JimHawkins
Thanks, Sergey
