prevent that only the 1st character in a cell is a number
at the input (memoKeyDown) of a text I want to prevent that only the 1st character in the cell is a number.
Example: 1. Es ... (wrong)
Es steht 1 Baum im Wald (correct)
procedure TForm1.memoKeyDown(Sender: TObject; var Key: Word; Shift: TShiftState);
var r,c,cs,rs, v,ItemNo,Offs,StyleNo,ParaNo: integer;
posFlag: boolean;
Cell: TRVTableCellData;
Table: TRVTableItemInfo;
if memo.InplaceEditor<>nil then begin //rveTabelle hat den Focus
rveTable.GetEditedCell(r,c);
if (c=0) and (key>47) and (key<58) then begin //lfd. Nr.
s:= rveTable.Cells[r,0].GetRVData.GetItemTextA(0); //Zellinhalt - necessary ?
ShowMessage(s+#10#10+
'In der 1. Spalte darf als 1. Zeichen keine Zahl stehen !');
SendKeys('{BACKSPACE}',true);
end; //of if memo.InplaceEditor<>nil
posFlag: boolean;
Thank you for your answere.
I understand the difference between memoKeyDown and memoKeyPress.
But that is not my problem.
I want that a number cannot stand as first character in a cell while I press 1 (a number).
1. Es ... (wrong).
but as x. character: Es waren 2 Versuche. (correct)
I think if I know where caret stands (caretPosition in cell) before I press a number
I can replace the number by #0.
procedure TForm1.memoKeyPress(Sender: TObject; var Key: Char);
rveTable.GetEditedCell(rveTzeile1,rveTspalte1);
if (rveTspalte1=0) and (carePosition=1) and (pos(key, '1234567890')>0) then begin
key:= #0;
ShowMessage('Zeilen ohne Beurteilungspalten oder weniger als x Spalten ...');
1. Es ... (wrong).
key:= #0;
Because I found no help, I tried some ideas.
Only with procedure TForm1.memoKeyDown(...) I found a solution:
var ...
if (rveTspalte1=0) and (key>47) and (key<58) then begin
Application.ProcessMessages; //<--------------------------------- !!
s:=rveTable.Cells[rveTzeile1,rveTspalte1].GetRVData.GetItemTextA(0);
if (s<>'') and (pos(s[1],'1234567890')>0) then begin
ShowMessage('Zeilen ohne Beurteilungspalten oder weniger als '+intToStr(cs)+
' Spalten dürfen in der'+#10+'(1. Zeile der) 1. Spalte keine Zahl (lfd. Nr.) haben !');
SendKeys('{BACKSPACE}',true); //works reliable - why not use ?
end; //of if (rveTspalte1=0) and
end; //of .memoKeyDown
if someone has a better codierung please tell us
var ...
This function returns True if the caret is at the beginning of rve.
Pass memo.TopLevelEditor as the parameter.
The function takes into account that:
- there may be a selection that will be removed on insertion
- there may be not only a single text item in this cell
function IsCaretAtTheBeginning(rve: TCustomRichViewEdit): Boolean;
var FirstItemIndex: Integer;
ItemNo1, Offs1, ItemNo2, Offs2: Integer;
FirstItemIndex := 0;
if rve.GetItemStyle(0)=rvsListMarker then
inc(FirstItemIndex);
rve.GetSelectionBounds(ItemNo1, Offs1, ItemNo2, Offs2);
if ItemNo1<0 then begin
ItemNo1 := rve.CurItemNo;
Offs1 := rve.OffsetInCurItem;
Result := (ItemNo1=FirstItemIndex) and (Offs1<=rve.GetOffsBeforeItem(ItemNo1));
