Saving Unicode Characters to RTF in OnSaveComponentToFile
nostra
Post by nostra »
I have a couple of controls (TEdit for example) inserted into a RichView Document and want to produce RTF containing text entered in those controls like this:
procedure TRichForm.RichMemoSaveComponentToFile(Sender: TCustomRichView;
  Path: string; SaveMe: TPersistent; SaveFormat: TRVSaveFormat;
  var OutStr: string);
 if SaveMe is TCustomEdit then
  OutStr := TCustomEdit(SaveMe).Text;
Unfortunately if those controls contain special Unicode characters like ☒ (U+2612) they do not get converted correctly.
What is the best way of saving components with Unicode characters to RTF to preserve all possible characters?
The component saves the returned OutStr to RTF as it is, without any processing. For Unicode versions of Delphi, it simply typecasts it to AnsiString before saving.
So you need to encode text to RTF yourself.
You can do it using an undocumented function from RVFuncs unit:
  OutStr := String(RVMakeRTFStrW(TCustomEdit(SaveMe).Text, Sender.Style.DefCodePage,
            rvrtfDuplicateUnicode in Sender.RTFOptions, False, False, False))
Note: this code is valid only for Unicode versions of Delphi (starting from Delphi 2009)
nostra
Post by nostra »
Thanks, works like a charm
