IDE Installer
IDE Installer
We released our installer program as freeware with source code:
http://www.trichview.com/ideinstall/
We created it for our own use, but if other developers like it, they can use it for installing their components.
This installer is suitable for installing both precompiled trial and source code versions of components.
IDE Installer v1.1
IDE Installer v1.1
fix: installing in RAD Studio 2007-2010
fix: installing cbproj packages
new: a new mode of uninstallation, uninstalling from all supported versions of Delphi and C++Builder
impr: when uninstalling from a command line, the installer starts and exits without a confirmation; this mode is optimal for calling from a larger uninstaller.
wdias
Post by wdias »
hi,
I tried to read the instructions, but the ReadMe.chm isn't work.
Could you check it? please
I downloaded and opened ReadMe.chm, it works.
Make sure that you open it from a local hard disk (not from network disk) and the path to the file does not include "#" character.
wdias
Post by wdias »
nevermind! You must unlock the file to see its content.
IDE Installer v1.2
IDE Installer v1.2
new: the installer can integrate CHM help files in RAD Studio IDE (for XE8 and 10 Seattle)
new: Delphi and C++Builder 10 Seattle are supported
Some minor improvements in UI and minor fixes.
IDE Installer v1.3
IDE Installer v1.3
impr: when there are no supported IDE found, the installer shows a message about it (instead of simply displaying a blank list)
