Toggle Header
don709
Toggle Header
Post by don709 »
This is a small procedure called from a button click event on the form to toggle the header on or off.
It seems to have stopped working and I have no idea why.
RVE is of type TSRichViewEdit
Not completely sure it it has to do with my updating to the Delphi XE7 version. From reading the forum posts on headers it seems that the commands to change displaying a header has changed but I can't seem to get it to display. Any ideas would be appreciated.
procedure TFormTextEditor.AddHeaderButtonClick(Sender: TObject);
  if IsEmpty(RVE.RVHeader) then
    if FileExists(ExeDir+'MedicalTemplates\Header.rtf') then
      RVE.RVHeader.LoadRTF(ExeDir+'MedicalTemplates\Header.rtf');
      RVE.Format;
  end
    RVE.RVHeader.Clear;
    RVE.Format;
  RVE.RichViewEdit.Modified := True;
Headers and footers were reworked in the last major update of ScaleRichView. The changes are related to implementation of separate headers for the first page and odd/even pages.
If you need to toggle visibility, you can (like in older versions) simply assign
RVE.PageProperty.HeaderVisible.
If you want to change the header content in code, your code is not correct in the new version of ScaleRichView.
In older versions, header was not only edited, but also stored in RVE.RVHeader. In the new version, it is stored in RVE.SubDocuments[]; RVHeader contains the header only while editing it.
So you can:
1) make sure that a header is not being edited (call RVE.StartEditing(srvrveMain))
2) Call RVE.SubDocuments[srvhftNormalHeader].LoadRTF (or Clear), then RVE.Format;
Alternatively, you can:
1) make sure that a header is being edited (call RVE.StartEditing(srvrveHeader))
2) change RVE.RVHeader
3) if you made changes by non-editing methods, like Clear or LoadRTF, call RVE.RVHeader.Change, then RVE.Format.
don709
First page only
Post by don709 »
The following code works as expected
    if IsEmpty(RVE3.RVHeader) then
        RVE3.StartEditing(srvrveMain);
        RVE3.SubDocuments[srvhftNormalHeader].LoadRTF('Header.rtf');
        RVE3.Format;
        RVE3.PageProperty.HeaderVisible := true;
    end
      RVE3.RVHeader.ClearAll;
      RVE3.SubDocuments[srvhftNormalHeader].Clear;
      RVE3.Format;
      RVE3.PageProperty.HeaderVisible := false;
However if I use srvhftFirstPageHeader no header appears.
RVE3.SubDocuments[srvhftFirstPageHeader].LoadRTF('Header.rtf');
instead of
I assumed changing srvhftNormalHeader to srvhftFirstPageHeader would give me the header only on the first page... any idea what I'm doing wrong.
Don
To show header and footer for the first page, assign RVE.PageProperty.TitlePage := True;
To show header and footer for even pages, assign RVE.PageProperty.FacingPages := True;
