I have been testing this component for a couple of days now and it looks like I need to buy it.
But I first need to figure out how to make bullets and numbering work on the DB version of the editor.
I have found a sample on this forum that has bullets and numbering, but when I copy the code to a DB version it stops working.
What might I be doing wrong?
Bullets and numbering
When the database is changed in an editing state, the content of DB-controls, including TDBRichViewEdit, may be reloaded.
In TRichView demos, the code for adding bullets is:
where CreateBullets may add a new item in RichViewEdit1.Style.ListStyles.
ApplyListStyle, before making the actual work, turns the database in an editing mode. So
1) bullets are added in RVStyle
2) database is switched to an editing state
3) the content of RichViewEdit (and the linked RVStyle) is reloaded, and the changes made on the step 1 are lost
4) the editor tries to apply non-existing bullets.
The solution: switching to an editing state before the whole operation. You can do in using CanChange:
RichViewEdit1.ApplyListStyle(CreateBullets,0,0,False,False);
if DBRichViewEdit1.CanChange then
DBRichViewEdit1.ApplyListStyle(CreateBullets,0,0,False,False);
I have made the button click like this now. But I still don't get any bullets.
The CreateBullets, CreateNumbering, GetListNo and CaretMove are copied from the demo in http://www.trichview.com/forums/viewtop ... +numbering
procedure TfrmMdEditor.btnBulletsClick(Sender: TObject);
if RichViewEdit.CanChange then
if btnBullets.Down then
RichViewEdit.RemoveLists(False)
RichViewEdit.ApplyListStyle(CreateBullets, 0, 0, False, False);
Sergey Tkachenko wrote:When the database is changed in an editing state, the content of DB-controls, including TDBRichViewEdit, may be reloaded.
In TRichView demos, the code for adding bullets is:where CreateBullets may add a new item in RichViewEdit1.Style.ListStyles.Code: Select all
The solution: switching to an editing state before the whole operation. You can do in using CanChange:Code: Select all
if DBRichViewEdit1.CanChange then DBRichViewEdit1.ApplyListStyle(CreateBullets,0,0,False,False);
That will take some work because I am using UniDAC as DB connection and some of my own utilities as well.
But I will give it a go and see if I can do it.
- is there a time limit and the trialversion I have installed? (if so I need to hurry up )
Sergey Tkachenko wrote:Can you send me a simple example to richviewgmailcom?
