Getting RVAddictSpell3 live autocorrect to work
johnF
Post by johnF »
In "actiontestaddict" demo, I can set "jimr" to autocorrect to "JimR" as I type.
However I am struggling to get that to happen in my own project.
I don't see any attach option for this post, but if you can let me know what needs changed after adding a TRichViewEdit and TRVAddictSpell3 to a new form that should be enough.
I know how to add Auto-Corrections to Custom Dictionary after clicking Options in spell check dialog.
Thanks, Jim.
See the commented code in the main unit of ActionTest projects.
procedure TForm3.RichViewEdit1KeyDown(Sender: TObject; var Key: Word;
  Shift: TShiftState);
  // uncomment if you use Addict3
  if Key = VK_RETURN then
    RVA_Addict3AutoCorrect(RichViewEdit1);
procedure TForm3.RichViewEdit1KeyPress(Sender: TObject; var Key: Char);
  if (Key in ['''', #13, #9]) or (Pos(Key, RichViewEdit1.Delimiters)<>0) then
