problem [urgent]
Ceprotec
problem [urgent]
Post by Ceprotec »
Hello Sergey,
I have a serious problem, this is my original text:
I save the text above in the database, but when you open it is cut:
I record in a table, where the field is type "image":
but it is not always what happens, see the code that opens the document:
            Stream := Query.CreateBlobStream(QueryMODELO,bmRead);
            SRichViewEdit1.RVHeader.Clear;
            SRichViewEdit1.RVFooter.Clear;
            SRichViewEdit1.RichViewEdit.Clear;
            SRichViewEdit1.RichViewEdit.LoadRVFFromStream(Stream);
            Stream.Free;
            SRichViewEdit1.RVHeader.Format;
            SRichViewEdit1.RVFooter.Format;
            SRichViewEdit1.SetRVMargins;
            FillFields(SRichViewEdit1.RichViewEdit.RVData); ///corpo do texto
            SRichViewEdit1.RichViewEdit.Format;
            FillFields(SRichViewEdit1.RVHeader.RVData); ///cabeçalho
            FillFields(SRichViewEdit1.RVFooter.RVData); ///rodape
what might be happening?
thanks.
Ceprotec
Post by Ceprotec »
this is the code to save the database:
QueryImpressos.Close;
QueryImpressos.Open;
QueryImpressos.UpdateObject := UpdateSQL1;
QueryImpressos.CachedUpdates := true;
QueryImpressos.Insert;
QueryImpressosTIPO.AsInteger := tipo.ItemIndex;
QueryImpressosDESCRICAO.AsString := descricao.Text;
QueryImpressosTIPO_ES.AsString := tipo.Text;
QueryImpressosFolhaInicial.AsString := QueryBuscaDadosFolhaInicial_liv.AsString
QueryImpressosFolhaFinal.AsString := QueryBuscaDadosFolhaFV.AsString;
QueryImpressosTermo.AsInteger := QueryBuscaDadosTermoFinal_liv.AsInteger;
QueryImpressosLivro.AsInteger := QueryBuscaDadosNumeroLivro_liv.AsInteger;
QueryImpressosCodigoEscritura.AsInteger := QueryTransCODIGO.AsInteger;
SRichViewEdit1.RVFOptions := SRichViewEdit1.RVFOptions - [rvfoSavePicturesBody];
SRichViewEdit1.RVHeader.RVFOptions := SRichViewEdit1.RVHeader.RVFOptions - [rvfoSavePicturesBody];
Stream := QueryImpressos.CreateBlobStream(QueryImpressosMODELO,bmWrite);
SRichViewEdit1.RichViewEdit.SaveRVFToStream(Stream,False);
Stream.Free;
QueryImpressos.Post;
QueryImpressos.ApplyUpdates;
QueryImpressos.CommitUpdates;
Please save this document in a file and send to richview gmail com
Ceprotec
Post by Ceprotec »
file sent, thank you.
I received your files.
The problem is not in loading, because the both your files end on "Pelos representantes legais da outorgad".
So the problem may be in saving. Please save the original document, containing the full text.
PS: there are potential problems in this code, however, they do not affect this bug:
1) before saving, the existing content of the stream must be cleared.
2) instead of
            Stream.Free;
the code must be:
            SRichViewEdit1.Clear;
            Stream.Free;
            SRichViewEdit1.Format;
3) If you use ScaleRichView 6 or newer, you need to apply FillFields to all SRichViewEdit1.SubDocuments[] instead of RVHeader and RVFooter.
Ceprotec
Post by Ceprotec »
this code is to load the file, but and save, correct?
I will send the original file by email.
