Change text color before printing
AndreMurta
Post by AndreMurta »
I'm creating a text editor based in the ActionTest demo.
I have included to the end customer the possibility to insert data fields stored in a TListBox control (lstGlobalVars), using the InsertStringTag function. Each entry in lstGlobalsVars is actually a key to a TDictionary class which stores the values related to the key indexes.
If the user double click the listbox control, the following function is called:
const
  TEXT_BOLD = 1;
  TEXT_ITALIC = 2;
  TEXT_UNDERLINE = 3;
  TEXT_APPLYFONTNAME = 4;
  TEXT_APPLYFONT = 5;
  TEXT_APPLYFONTSIZE = 6;
  TEXT_COLOR = 7;
  TEXT_BACKCOLOR = 8;
  TEXT_FIELDPROTECT = 9;
procedure TfLstGlobalVars.lstGlobalVarsDblClick(Sender: TObject);
  idx: integer;
  idx := lstGlobalVars.ItemIndex;
  with fMain do
    SRichViewEdit1.RichViewEdit.ApplyStyleConversion(TEXT_FIELDPROTECT);
    SRichViewEdit1.RichViewEdit.InsertStringTag(
      DictVars.Items[lstGlobalVars.Items[idx]],
    SetFocus;
I have the following procedure vinculated to the OnStyleConversion event in the TSRichViewEdit control:
procedure TfMain.SRichViewEdit1StyleConversion(Sender: TCustomRichViewEdit; StyleNo, UserData: Integer; AppliedToText: Boolean; var NewStyleNo: Integer);
  FontInfo: TFontInfo;
  FontInfo := TFontInfo.Create(nil);
    FontInfo.Assign(Sender.Style.TextStyles[StyleNo]);
    case UserData of
      TEXT_FIELDPROTECT:
        FontInfo.Protection := [rvprStyleProtect, rvprModifyProtect, rvprStyleSplitProtect, rvprConcateProtect, rvprRVFInsertProtect, rvprDoNotAutoSwitch];
        FontInfo.BackColor := clSilver;
    NewStyleNo := Sender.Style.TextStyles.FindSuchStyle(StyleNo, FontInfo,
                                                       RVAllFontInfoProperties);
    if NewStyleNo=-1 then
      Sender.Style.TextStyles.Add;
      NewStyleNo := Sender.Style.TextStyles.Count-1;
      Sender.Style.TextStyles[NewStyleNo].Assign(FontInfo);
      Sender.Style.TextStyles[NewStyleNo].Standard := False;
    FontInfo.Free;
So, when the user double click the listbox, the field is inserted with "clSilver" as the text background color, the field contents are protected against editing.
This alternative background color is good on screen, but I would like to change it back to clNone (or clWindow) when the document is printed. I have no clue about how to do it. Is it possible?
You can try using OnApplyStyleColor event.
Create a global variable PrintingDoc: Boolean, assign True to it while printing.
Assign this code to SRV.RichViewEdit.Style.OnApplyStyleColor:
procedure TForm3.RVStyleApplyStyleColor(Sender: TRVStyle; Canvas: TCanvas;
  StyleNo: Integer; DrawState: TRVTextDrawStates; ApplyTo: TRVColoredParts;
  var DoDefault: Boolean);
  if PrintingDoc then begin
    Sender.TextStyles[StyleNo].ApplyColor(Canvas, Sender, DrawState, True, rvcmPrinterColor);
    if rvprStyleProtect in Sender.TextStyles[StyleNo].Protection then begin
      Canvas.Brush.Color := clNone;
      Canvas.Brush.Style := bsClear;
    DoDefault := False;
AndreMurta
Your solution worked, but I had to change the way to use it, since I could not find an event triggered at the end of the document printing, in order to setup PrintingDoc value back to false.
I just created a menu item called "Highlight Fields" which can be checked/unchecked. Depending on the item status I call SVR.RichViewEdit.Repaint to highlight or not the fields. It's not exactly what I expected but it works.
Thanks a lot. Your suite of components is just great.
