when I want to install the RVPkgDXE7 package from TRichView , I have the following error [dcc32 Fatal Error] RVPkgDXE7.dpk (108): F1026 File not found: RichViewActions \ CRVData.dcu
I check the directory RichViewActions and there is no file called CRVData.dcu
What am I doing wrong ?
Installation in Embarcadero XE7
May be this error happens when compiling RichViewActionsDXE7.dpk, not RVPkgDXE7.dpk?
Because CRVData unit is included in TRichView, not in RichViewActions.
If yes:
1) Install RVPkgDXE7.dpk, it must be installed before RichViewActionsDXE7.dpk.
2) Paths to TRichView and RichViewActions must be added in Delphi library path. Open menu Tools | Options, page Environment Options | Delphi Options | Library, make sure that Selected platform = 32-bit Windows, add the paths to Library paths.
If yes:
