Open RSS channel
volod3000
Open RSS channel
Post by volod3000 »
Try to view the rss-channel in RichView, through RichViewXML, but always a mistake
(No root element.) and in RichView empty
That's part of the code:
var rssUrl: String = 'http://112.ua/rss';
procedure TForm1.Button2Click(Sender: TObject);
   RssXml: String;
   Stream: TFileStream;
   f: TextFile;
    RichViewEdit1.Clear;
    AssignFile (f, 'myxml.txt');
    Rewrite (f);
      IdHTTP1.HandleRedirects := true;
      IdHTTP1.ReadTimeout := 5000;
      IdHTTP1.Request.ContentEncoding := 'UTF-8';
    cli:= 2;
      RssXml := IdHTTP1.Get(rssUrl);
  except
    on E: Exception do
      ShowMessage ('Error: ' + E.Message);
      Exit;
     WriteLn (f, RssXml);
     CloseFile (f);
     Stream := TFileStream.Create('myxml.txt', fmOpenRead);//properties.xml
     Stream.Position:= 0;
    except
     ShowMessage('Файл не может быть загружен.');
     Exit;
     RichViewXML1.RootElement:= 'channel';
     RichViewXML1.LoadFromStream(Stream);
     RichViewEdit1.Format;
     Stream.Free;
procedure TForm1.RichViewEdit1Jump(Sender: TObject; id: Integer);
      ItemNo: Integer;
      RVData: TCustomRVFormattedData;
      s: String;
      Tag: string;
  RichViewEdit1.GetJumpPointLocation(id, RVData, ItemNo);
  Tag := RVData.GetItemTag(ItemNo);
  RichViewXML1.LoadFromFile(RichViewXML1.BaseFilePath +Tag + '.xml');
That's part of the code xml
<?xml version="1.0" encoding="UTF-8"?>
<rss version="2.0" xmlns:atom="http://www.w3.org/2005/Atom">
    <channel>
        <title>Новости 112.ua</title>
        <link>http://portal.112.ua/</link>
        <description>112.UA RSS feed</description>
        <language>ru-ru</language>
        <pubDate>Tue, 24 Feb 2015 14:02:10 +0200</pubDate>
        <ttl>300</ttl>
        <image>
            <url>http://112.ua/static/img/logo_112_ru.jpg</url>
            <title>Новости 112.ua - </title>
        </image>
        <item>
            <title><![CDATA[Гуманитарное сообщество заявляет о намерении привлечь 316 млн долл. для помощи 3,2 млн украинцев]]></title>
            <link>http://112.ua/ekonomika/gumanitarnoe-soobschestvo-zayavlyaet-o-namerenii-privlech-316-mln-doll-dlya-pomoschi-3-2-mln-ukraincev-194993.html</link>
            <description><![CDATA[ <img src="http://image.112.ua/300x225/Jan2015/117935.jpg" alt="новости 112"/>
            По словам Уокера, более 2 миллиона человек проживает в районах, временно неподконтрольных Украине и также нуждается в поддержке, поскольку доступ к услугам у них ограничен]]></description>
            <fulltext><![CDATA[]]></fulltext>
            <pubDate>Tue, 24 Feb 2015 13:59:33 +0200</pubDate>
            <category>Экономика</category>
            <guid>http://112.ua/ekonomika/gumanitarnoe-soobschestvo-zayavlyaet-o-namerenii-privlech-316-mln-doll-dlya-pomoschi-3-2-mln-ukraincev-194993.html</guid>
            <enclosure length="8" url="http://image.112.ua/300x225/Jan2015/117935.jpg" type="image/jpeg"/>
        </item>
</channel>
</rss>
Do not scold much, I'm just learning.
Where the error, please tell me.
RichViewXML is not designed to view arbitrary XML documents.
It allows saving TRichView document in XML and loading it.
volod3000
Post by volod3000 »
Sergey Tkachenko wrote:RichViewXML is not designed to view arbitrary XML documents.
Understood you, thank you
