Problems with sound
Problems with sound
Post by 11111 »
I tried using compiled demos of Chat and server, and everything works well except Sound.
I will try to describe problem in russian because my english isn't sufficient for this.
описание проблемы со звуком при передаче через микрофон:
Звук то передаётся то нет, возможно нужно сделать демку где бы передача звука инициировалась бы по нажатию кнопки.
Иногда вместо звука передаётся шум.
Если звук всёже передаётся то передаётся, в урезанном виде, без начала и конца.
Answered by email
11111
Post by 11111 »
Thanks for answer, but
Please resend your answer to "imsh2 @ gmx com"
because profile mail is disposable mail box, and I can't receive messages from it :/
We resent the email, do you receive it?
catch1amo
I have de same problem
Post by catch1amo »
Sergey Tkachenko wrote:We resent the email, do you receive it?
I'm testing the chat compiled examples. The video runs fine but no audio. could share me the solution?
1) Did you download the newest version of RVMedia demos from the web site? The previous versions did not play sound.
2) How many clients do you connect to the server?
3) Does this problem occur if you:
- do not send video
- send video from webcam
- send video from some sample Internet camera
4) Which traffic the server shows?
catch1amo
Post by catch1amo »
Sergey Tkachenko wrote:1) Did you download the newest version of RVMedia demos from the web site? The previous versions did not play sound.
- do not send video
Thanks for responding.
1. I download the software versions a couple of days.
2. Connect two clients
3. In all cases the error occurs
4. Only the demos were using the network
Modifying the example source code, I found if I change the compression settings of trvcamsender , audio works
The problem presented using rvtcParts. If use rvtcFully or rvtcNone the problem does not arise and operates
Thank you for finding the source of this problem.
We confirm problems with this type of compression, they were added in recent updates. We are working to fix it.
