How do I connect a TRVStyleTemplateComboBox to a TSRichViewEdit in Delphi 5.
The same question for a TRVFontComboBox and a TRVFontSizeCombobox.
In Delphi 5 there is no property "Editor" and when I try to connect them through code I get an error: Incompatible types: 'TCustomRichViewEdit' and 'TSRichViewEdit'
TRVStyleTemplateComboBox and Delphi 5
The component TSRichViewEdit property version = v4.7.2
The package is: 13.12.1
So, in the version I have it is not possible?
Is the latest version compatible with Delphi 5?
Do you have sample code to fill and update the comboboxes?
