Font in Demo ActionTestTabs
Gwiasda
Post by Gwiasda »
In this demo is the default font Arial. How can I set the default font for example to Calibri? In the designer or in the code.
If you use StyleTemplates (like in the ActionTest demo), set the font for 'Normal' style template in rvActionNew.StyleTemplates
If StyleTemplates are not used, change the font for TextStyles[0] in TrvActionNew.OnNew event (the link contains an example code)
Gwiasda
ActionTestUni Demo
Post by Gwiasda »
Thanks for your answer,
I have in the ActionTestUni Demo in then unit „dmActionsSRVAlpha“ in the „Actionlist1“ „rvActionNew1.StyleTemplates“ Normal found. In the property „Textstyle“ I change the Fontname to Times New Roman. But in the application appears ever Arial. What is wrong?
Neither modification appears in the application.
Include rvfiFontName in ValidTextStyleProperties of this style template.
Properties not listed in ValidTextStyleProperties are ignored (inherited from the parent style, or (if no parent, like in the case with 'Normal') default values are used).
Gwiasda
Post by Gwiasda »
Thank you,
it’s works now fine.
