LoadCustomFormat & SaveCustomFormat on DBRichViewEdit
merlinofchaos
Post by merlinofchaos »
I'm trying to zip stream befor recording and unzip it on reading. About backing everything is OK, but when you try to load it in DBRichViewEdit by LoadCustomFormat text on edit stay empty....
My functions is:
procedure Tfe_DocEdit.RichViewEdit1LoadCustomFormat(Sender: TCustomRichView;
  Stream: TStream; var DoDefault: Boolean);
  AbUnZ : TAbUnZipper;
  MS : TMemoryStream;
  StreamHeader : Int64;
  inherited;
  StreamHeader:= 0;
  if (Stream as TMemoryStream).Size > 10 then
      (Stream as TMemoryStream).Position:=0;
      (Stream as TMemoryStream).Read(StreamHeader,4);
  // Zip signature
  if (StreamHeader = 67324752) then
      MS:= TMemoryStream.Create;
        AbUnZ:= TAbUnZipper.Create(Nil);
        AbUnZ.Stream:=
          (Stream as TMemoryStream);
        AbUnZ.ExtractToStream(AbUnZ.Items[0].FileName,MS);
        MS.Position:= 0;
        (Sender as TDBRichViewEdit).InsertRTFFromStreamEd(MS);
        // It's from debug- file is corectly unziped
        MS.SaveToFile('D:\ZZRtf' + FormatDateTime('ddmmyyhhmmss',now) + '.rtf');
        Sender.SetSelectionBounds(0,0,0,0);
        DoDefault:= False;
        FreeAndNil(MS);
        FreeAndNil(AbUnZ);
For zip I use (it work):
procedure Tfe_DocEdit.RichViewEdit1SaveCustomFormat(Sender: TCustomRichView;
  AbZ : TAbZipper;
  SStream : TMemoryStream;
  MS : TMemoryStream;
  AbZ:=
    TAbZipper.Create(nil);
    AbZ.ArchiveType:= atZip;
    AbZ.ForceType:= True;
    SStream:= TMemoryStream.Create;
    Sender.SaveRTFToStream(SStream, False);
    AbZ.Stream:= MS;
    AbZ.AddFromStream('zipRTF.rtf', SStream);
    AbZ.Save;
    if (Sender as TDBRichViewEdit).DataSource.DataSet.State in [dsEdit, dsInsert] then
        (Stream as TMemoryStream).LoadFromStream(MS);
        (Sender as TDBRichViewEdit).DataSource.DataSet.FieldByName('DocFormat').AsInteger:= 2;
    DoDefault:= False;
    FreeAndNil(AbZ);
    FreeAndNil(MS);
    FreeAndNil(SStream);
Any ideas what is wrong in onload function?
Try using LoadRTFFromStream instead of InsertRTFFromStreamEd
