how to capture desktop audio
thanks
In the current version, TRVMicrophone reads sound from the default sound recording device.
To capture all audio output using TRVMicrophone, set "Stereo mixer" as a default sound recording device. Open the Control Panel, open "Sound", tab "Recording". If you can see "Stereo mixer" here, enable it and make the default device (using a right-click menu). If you cannot see it here, right-click, check "Show Disabled Devices" and "Show Disconnected Devices". You still cannot see it here - bad luck, it is unsupported by your system.
Probably, in future, we will add an ability to choose a recording device for TRVMicrophone.
PS: we noticed a bug in the last RVMedia update which prevents receiving audio data. We will upload a fixed version today.
