[Example][ScaleRichView] How to draw line numbers
Update: this code is not needed in new version of ScaleRichView, because this is a standard feature, see TSRichViewEdit.LineNumberProperty
Assign this code to TSRichViewEdit's OnPaintPage event.
The code draws line numbers at the left margin.
Numbering is restarted on each page.
procedure TForm1.SRichViewEdit1PaintPage(Sender: TObject; PageNo: Integer;
  PageRect, R: TRect; Canvas: TCanvas; Prepaint, Printing: Boolean);
const
  PageNumberDX = 5; // distance between line numbers and text
  i: Integer;
  FirstItemNo, LastItemNo, Offs, ItemPart: Integer;
  FirstPageNo, LastPageNo : Integer;
  ItemRect: TRect;
  srv: TSRichViewEdit;
  TextHeight, LineNumber, Left, Top, LeftMargin: Integer;
  // line number font
  Canvas.Font.Name := 'Tahoma';
  Canvas.Font.Size := 6;
  Canvas.Font.Style := [];
  Canvas.Font.Color := clBtnShadow;
  Canvas.Brush.Style := bsClear;
  TextHeight := Canvas.TextHeight('0');
  srv := Sender as TSRichViewEdit;
  srv.GetPageStartItemNo(PageNo, FirstItemNo, Offs);
  srv.GetPageLastItemNo(PageNo, LastItemNo, Offs);
  LineNumber := 1;
  LeftMargin := srv.GetLeftMargin100Pix(PageNo);
  for i := FirstItemNo to LastItemNo do begin
    if srv.RichViewEdit.GetItemStyle(i)=rvsTable then
      continue;
    ItemPart := 0;
    while srv.GetItemBounds100(
      srv.RichViewEdit.RVData, i, ItemRect,
      FirstPageNo, LastPageNo, ItemPart) do begin
      if (FirstPageNo = PageNo) and
         ((ItemPart>0) or srv.RichViewEdit.IsFromNewLine(i)) then begin
          Left := PageRect.Left + LeftMargin - PageNumberDX -
            Canvas.TextWidth(IntToStr(LineNumber));
          Top := PageRect.Top + (ItemRect.Top+ItemRect.Bottom - TextHeight) div 2;
          Canvas.TextOut(Left, Top, IntToStr(LineNumber));
        inc(LineNumber);
      inc(ItemPart);
Screenshot:
Last edited by Sergey Tkachenko on Fri Oct 02, 2015 9:42 am, edited 1 time in total.
Jim Knopf
Post by Jim Knopf »
Oh, I saw it only now - thank you!
I think we will add line numbers as a built-in option in TSRichViewEdit.
Line numbers is a standard feature since ScaleRichView 6.5 (available for registered users)
Line numbers in TRichView FireMonkey
This code for OnPaint event draws line numbers in FireMonkey version of TRichView.
Line numbers are drawn on the left margin, so the value of LeftMargin property must be large enough.
The following values can be customized:
- distance from the right side of numbers to the right side of the left margin (PageNumberDX constant)
- font name, size and color of line numbers (this example uses 'Arial', 8, Blueviolet)
uses fmxCRVData, fmxDLines;
procedure TfrmMain.rvePaint(Sender: TCustomRichView; ACanvas: TCanvas;
  Prepaint: Boolean);
const
  i: Integer;
  TextHeight: Single;
  LineNumber: Integer;
  rv: TCustomRichView;
  R: TRectF;
  DItem: TRVDrawLineInfo;
  MinY, MaxY, ZoomRatio: Single;
  if Prepaint then
  rv := Sender as TCustomRichView;
  if not (rvflRoot in rv.Flags) then
  ZoomRatio := rv.ZoomPercent / 100;
  Canvas.Font.Family := 'Arial';
  Canvas.Font.Size := 8 * ZoomRatio;
  Canvas.Fill.Color := TAlphaColorRec.Blueviolet;
  LineNumber := 1;
  MinY := rv.ClientToDocument(TPointF.Create(0, 0)).Y;
  MaxY := MinY + rv.Height;
  for i := 0 to rv.RVData.DrawItems.Count - 1 do
    DItem := rv.RVData.DrawItems[i];
    if DItem.FromNewLine then
      R := TRectF.Create(0, DItem.Top - TextHeight,
        (rv.LeftMargin - PageNumberDX) * ZoomRatio,
        DItem.Top + DItem.Height + TextHeight);
      if R.Top > MaxY then
      if R.Bottom >= MinY then
        Canvas.FillText(R, IntToStr(LineNumber), False, 1, [],
           TTextAlign.Trailing, TTextAlign.Center);
      inc(LineNumber);
