procedure TForm1.pTest1Click(Sender: TObject);
var table: TRVTableItemInfo;
DItemNo, DItemOffs, X, Y: integer;
rve := rve.TopLevelEditor;
rve.RVData.Item2DrawItem(rve.CurItemNo, rve.OffsetInCurItem, DItemNo, DItemOffs);
rve.RVData.GetOriginEx(X, Y);
ShowMessage(intToStr(x)+', '+intToStr(y)); //seems to be oK
// but now ?
// I don't find an issue as rve.RVData.SEToriginEx(X, Y);
2 table haven't the same distance from left memo-border
Re: 2 table haven't the same distance from left memo-border
j&b wrote:procedure TForm1.pTest1Click(Sender: TObject);
{Some unnessary variable:
VAR table: TRVTableItemInfo;
DItemNo, DItemOffs,}
var X, Y: integer;
//rve.RVData.Item2DrawItem(rve.CurItemNo, rve.OffsetInCurItem, DItemNo, DItemOffs);
// but now ?
j&b wrote:j&b wrote:procedure TForm1.pTest1Click(Sender: TObject);
Oh, oh ...
var X, Y: integer;
rve: TCustomRichViewEdit;
No x. quote !
I think I was on the wrong track (Holzweg).
It is related to rvRuler (Left Indent).
In the following procedure the variable 'old' does not show the correct position (LeftIndent) of the table.
Who has a solution?
procedure TForm1.pT1Click(Sender: TObject);
var s1,s2,old: string;
nWert: Extended;
ok: boolean;
label nmal;
old:= floatToStr(rvruler1.LeftIndent);
s1:='Linken Einzug nach links/rechts verschieben';
s2:='Zur Zeit: '+old+#10#10+
'Vergrößern: 0,01 bis +5'+#10+
'Verkleinern: - 5 bis -0,01'+#10;
s:= '0,1';
nmal:
oK := InputQuery(s1,s2, s);
if oK = false then exit //abbrechen oder ESC
else begin
nWert:= StrToFloatDef(s,strToFloat(old));
if (nWert<-5) or (nWert>5) then goto nmal;
rvruler1.LeftIndent:= rvruler1.LeftIndent+nWert;
Who has a solution?
nWert: Extended;
ok: boolean;
label nmal;
s:= '0,1';
nmal:
else begin
