system requirements
costa
system requirements
Post by costa »
Hello:
Could you please tell me if you support XE7? Is your component compatible with FireMonkey?
XE7 is supported, 32bit and 64bit VCL.
FireMonkey is not supported yet.
costa
Post by costa »
Does it mean you plan to add support for FireMonkey in the future?
Yes, but I cannot say when it will be implemented, so please do not rely on it.
