I'm using RichViewEdits + toolbars with some RichViewActions on them in two different ways:
1. On a normal form, which is being showed modal
2. On a form, which gets assigned to a cxGrid column as its PopupEdit
In the second case there is a problem, that once I execute the ToolButton with TrvActionFontColor assigned to it, the ColorPicker gest showed, which closes my PopupEdit, so that only the ColorPicker remains visible and any selected color doesn't have any effect.
Is there a way to change this behaviour somehow? To pass in a panel placed on the form, which gets filled with color selection buttons without to show the ColorPicker-form maybe?
Wanted to try to use a RVColorCombo, but
- don't see how to get it to work with a certain RichViewEdit and
- it seems to use the same ColorPicker as the TrvActionFontColor
Executing TrvActionFontColor closes the parent PopupEdit
You can use any colorpicker control (provided by DevExpress, or RVColorGrid).
When the color is chosen, the simplest way to apply it to text is using TrvActionFontColor in a "silent" mode:
rvActionFontColor.UserInterface := rvacNone;
rvActionFontColor.Color := RVColorGrid.ChosenColor
rvActionFontColor.ExecuteTarger(RichViewEdit);
// here you can restore the old value of rvActionFontColor.UserInterface
