I’m having difficulty to compile rvHtmlViewImportD2010 in Delphi 2010.
I download the source code the website and from code.google. both has issue
If deactivate GOOGLECODE or not,
If deactivate GOOGLECODE I get 65 errors
[DCC Error] rvHtmlViewImport.pas(199): E2003 Undeclared identifier: 'TSectionList'
[DCC Error] rvHtmlViewImport.pas(343): E2003 Undeclared identifier: 'BorderStyleType'
[DCC Error] rvHtmlViewImport.pas(344): E2003 Undeclared identifier: 'TMarginArray' so on
And If activate GOOGLECODE I get 15 errors
[DCC Error] rvHtmlViewImport.pas(1283): E2003 Undeclared identifier: 'CellSpacingVert'
[DCC Error] rvHtmlViewImport.pas(1284): E2003 Undeclared identifier: 'CellSpacingHorz'
[DCC Error] rvHtmlViewImport.pas(1285): E2003 Undeclared identifier: 'CellSpacingVert' so on,
I did read readme.txt, but has some outdated information that doesn’t exists in some pas
For example , read me says do this:
In "HTMLUn2.pas" in class "TChPosObj"
TChPosObj = class (TIDObject)
public < -- change "private" to "public", so we can access ChPos
ChPos: integer;
List: TList;
But there is no TChPosObj = class (TIDObject) in HTMLUn2.pas
Hope someone can help me to compile it without error, Thanks
rvHtmlViewImportD2010 Error
Probably you downloaded not the newest version of THTMLViewer from googlecode.
It can be downloaded using SVN.
If you never worked with SVN before, I recommend to download free svn client http://tortoisesvn.net/
Then create any folder, right click in Explorer, choose the command “SVN Checkout”, paste in “URL or repository” the address http://thtmlviewer.googlecode.com/svn/trunk/ , click OK
In future, to update to newer revision, right click this folder and choose “SVN Update”
