Different background for the first page
sylvainl
Post by sylvainl »
I have a TScaleRichViewEdit (v6), with header+footer differents for the 1st page (PageProperty.TitlePage := True).
I would like to have a different page background for the 1st page.
I tried to play with the OnPaintPage event,
as suggested here http://www.trichview.com/forums/viewtop ... 7146#27146
I can't get it working as I would like... I get the backgrounds behind my document, but the headers doesn't show (looks like they're drawn behind the background).
The problem is only with header/footer.
How can I do that (headers/footers AND background different for 1st page) ?
Thanks for your help :)
SylvainL
Sorry for not replying.
We fixed this problem in our internal version, and I immediately forgot about it, because we were busy releasing RVMedia :(
This fix will be included in the next update.
By the way, there are options to implement it without custom drawing events.
Here is a related topic: http://www.trichview.com/forums/viewtopic.php?t=6628
sylvainl
Post by sylvainl »
Thanks for your answer. Ok, understand for the fix. Will wait for it.
I will also go and read the topic about other implementations.
SylvainL
Fixed in SRV 6.1.2 (available for registered users)
sylvainl
Post by sylvainl »
I tried with the new version, it works perfectly.
Thanks, Sergey
