Merge cells
mohsen24000
Merge cells
Post by mohsen24000 »
I have a table with 3 cols in row.
I want merge cells 1,2 together in rows 0,1,2 and merge cells 0,1 in rows 3,4,5 and again merge cells 1,2 in rows 6,7,8 and so on.
but when use
when row is 0,1,2,6,7,8
table.MergeCells(row,1,2,1,true);
when row is 3,4,5
table.MergeCells(row,0,2,1,true); <-- beep and does not work;
Please guide me :(
I tried:
var table: TRVTableItemInfo;
  table := TRVTableItemInfo.CreateEx(9, 3, RichViewEdit1.RVData);
  table.MergeCells(0, 1,2,1,true);
  table.MergeCells(1, 1,2,1,true);
  table.MergeCells(2, 1,2,1,true);
  table.MergeCells(3, 0,2,1,true);
  table.MergeCells(4, 0,2,1,true);
  table.MergeCells(5, 0,2,1,true);
  table.MergeCells(6, 1,2,1,true);
  table.MergeCells(7, 1,2,1,true);
  table.MergeCells(8, 1,2,1,true);
  table.CellBorderWidth := 1;
  RichViewEdit1.InsertItem('', table)
This code works as expected.
mohsen24000
Thanks a lot.
I want to implement chat room such as whatsapp.
my chats appear left and others in right.
is table suitable for this or bitmap generation!?
Sorry, I do not understand the question
mohsen24000
I think using bitmaps is not a good idea, because users may want to copy-paste text.
I think you can use events for custom drawing.
For example, if you use tables, you can use OnDrawBorder.
mohsen24000
No problem for copy-paste text!
chats inserted into dbase and bitmap insert in TRichView with tag -> message id in dbase.
my issue is :
1- Speed 2- optimized implementation of the program
I would implement it as a table with custom drawn background (in table.OnDrawBorder event).
mohsen24000
Please a little guidance!
thanks a lot :)
For example, you can use 1x1 table for each message, and draw table background.
Simple text for inserting table in RichViewEdit. This table shows rounded rectangle as a background:
procedure TForm3.ToolButton68Click(Sender: TObject);
  table := TRVTableItemInfo.CreateEx(1,1, RichViewEdit1.RVData);
  table.OnDrawBorder := DrawTableBorder;
procedure TForm3.DrawTableBorder(Sender: TRVTableItemInfo;
    Canvas: TCanvas; Left,Top,Right,Bottom: Integer;
    Width: TRVStyleLength;
    LightColor, Color, BackgroundColor: TColor;
    Style: TRVTableBorderStyle; Printing: Boolean;
    VisibleBorders: TRVBooleanRect; Row, Col: Integer;
    var DoDefault: Boolean);
  if Row>=0 then
  Canvas.Pen.Color := clRed;
  Canvas.Pen.Style := psSolid;
  Canvas.Pen.Width := 1;
  Canvas.Brush.Color := clYellow;
  Canvas.Brush.Style := bsSolid;
  Canvas.RoundRect(Left, Top, Right, Bottom, (Right-Left) div 2, (Bottom-Top) div 2);
  DoDefault := False;
Some additional measures should be taken if cells can be edited, but, as I understand, you do not need editing these tables.
Note that OnDrawBorder for a table is called before drawing the table content, so it can be used for drawing background.
mohsen24000
Thank you
unfortunately, when i want draw rounded background for cells, it's draw on content of cell, no behind! :(
if row<0 then
Which version of TRichView do you use?
Version 15 draws the border before content.
If you use older version, you can change the code drawing only on border areas, since balloon background is a plain text.
mohsen24000
version 14
please guide , how do it!?
It's strange, I looked in the code of TRichView 14, it draws table border before (i.e. below) contents too.
Do you added the code
if Row>=0 then
Cell borders are drawn after (i.e. above) the cell content.
mohsen24000
Problem is here!
I want draw rounded background for cells
if row<0 then
