64bit compile
aaangeli
64bit compile
Post by aaangeli »
Hi, I’m installing my new TRichview component. I’m having trouble with 64bit compiling. How doy you suggest to made it? If I add 64bit target to RVPkgDXE7 package I could not compile it because of the required package designeide. Should I create a new package?
Davide
The simplest way is just creating 64-bit project, without making additional packages.
Build this project, and TRichView units (dcu fles) will be rebuilt as 64-bit units.
aaangeli
Post by aaangeli »
Ok thanks!
