The simplest way to set the style of a table cell
stegemma
Post by stegemma »
I've my grid class, that works fine and use its own styles. I want to insert that grid in a TRichViewEdit component. All's ok for cell text and borders but i can't set font styles (name, size...) and text alignment.
I convert my styles to TFontInfo and add it to TRVStyle:
int AddStyle(TRVStyle *rvs, TFontInfo *pFontInfo)
  rvs->TextStyles->Add();
  int NewStyleNo = rvs->TextStyles->Count - 1;
  rvs->TextStyles->Items[NewStyleNo]->Assign(pFontInfo);
  rvs->TextStyles->Items[NewStyleNo]->Standard = false;
  return NewStyleNo;
[/quote]
In my style objects, i store the returned NewStyleNo into an UserData integer, to use it when i later add cells from my grid to TRichView:
[code]
            if(TRVTableCellData *pCell = pTable->Cells[r][c])
              clsString sText  = "some text";
              if(TLigsStyle *pStyle = ligsprinter->GetStyleP(sStyle))
                  pCell->GetTable()->AssociatedTextStyleNo  = pStyle->UserData;
              pCell->SetItemText(0, CS(sText));
The problem seems to be in GetTable()->AssociatedTextStyleNo that seems to do nothing or maybe i've not undesrtood how styles works, in TRichViewEdit?
[/quote]
stegemma
Post by stegemma »
Please, excuse me for the bad formatting of previous message.
I've found a solution but it is very slow:
                pTable->Select(r, c, 0, 0);
                rve->ApplyTextStyle(pStyle->UserData);
Maybe is enough to disable updates of the control while inserting cells.
stegemma
Post by stegemma »
Using BeginUpdate/EndUpdate doesn't change the speed, this solution is too slow :(
I would like to know if there's some sample about the correct way to use ApplyTextStyle or ApplyParaStyle, in a fast way.
Setting font and alignment should be a simple task, for such kind of component, but i'm loosing on this details.
stegemma
Post by stegemma »
It seems that the slow down is do to this commands:
                rve->ApplyTextStyle(textStyleNo);
                rve->ApplyParaStyle(paraStyleNo);
I have to do it for any cell in the grid. If i only add text, the grid would be created almost instantly, if i set text/para style it requires 8 seconds for a 30 rows x 10 columns table.
There is a way to speed up apply text/para styles?
Thanks.
Before inserting the table, call:
for (int r = 0; r<pTable->RowCount; r++)
  for (int c = 0; c<pTable->ColCount; c++)
    pTable->Cells[r][c]->Clear();
    pTable->Cells[r][c]->AddNL('', textStyleNo, paraStyleNo);
As for AssociatedTextStyleNo, this property is implemented only in items that are linked to text style, i.e. in tabs and labels. This property is for internal use.
stegemma
Post by stegemma »
It works and it is very fast, now.
Thanks.
