[Example] DeleteBlankLines, RemoveParagraphBreaks, etc.
This code deletes all empty lines:
procedure DeleteBlankLines(RVData: TCustomRVData);
var i,r,c: Integer;
    table: TRVTableItemInfo;
  for i := RVData.ItemCount-1 downto 0 do
    if RVData.IsFromNewLine(i) and (RVData.GetItemStyle(i)>=0) and
      (RVData.GetItemText(i)='') and (RVData.ItemCount>1) and
      ((i = RVData.ItemCount - 1) or RVData.IsFromNewLine(i+1)) then
      RVData.DeleteItems(i,1)
    else if RVData.GetItem(i) is TRVTableItemInfo then
          if table.Cells[r,c]<>nil then
            DeleteBlankLines(table.Cells[r,c].GetRVData);
This procedure cannot be undone/redone. If called for editor, the editor's undo buffer becomes incorrect, so call ClearUndo.
Call:
DeleteBlankLines(RichViewEdit1.RVData);
RichViewEdit1.ClearUndo;
RichViewEdit1.Format;
[+] History of changes
2018-May-28: making sure that the deleted item is a single line; changed IsParaStart to IsFromNewLine
This procedure removes all line breaks that can be removed:
procedure RemoveParagraphBreaks(RVData: TCustomRVData);
var i,r,c: Integer;
    if (i>0) and RVData.IsFromNewLine(i) and
       not RVData.GetItem(i).GetBoolValue(rvbpFullWidth) and
       not RVData.GetItem(i-1).GetBoolValue(rvbpFullWidth) and
       (RVData.GetItemStyle(i)<>rvsListMarker) then
      RVData.GetItem(i).SameAsPrev := True
            RemoveParagraphBreaks(table.Cells[r,c].GetRVData);
This function cannot be undone/redone. If it's called for editor, information in the editor's undo buffer becomes incorrect, so you need to call RichViewEdit.ClearUndo.
In some cases, documents after calling this functions do not conform to the rules of valid RichView document (see the help file, "Valid
Documents" topic).
In order to fix it, call NormalizeRichView procedure from RVNormalize.pas. This unit is included in RichViewActions.
Call:
  RemoveParagraphBreaks(RichViewEdit1.RVData);
  NormalizeRichView(RichViewEdit1.RVData);
Modification of DeleteBlankLines - removing blank lines only from the end of the document:
procedure DeleteTrailingBlankLines(RVData: TCustomRVData);
var i: Integer;
  for i := RVData.ItemCount-1 downto 1 do
    if RVData.IsParaStart(i) and (RVData.GetItemStyle(i)>=0) and
      (RVData.GetItemText(i)='') then
      break;
Call:
Last edited by Sergey Tkachenko on Thu Aug 23, 2012 5:59 pm, edited 1 time in total.
This procedure converts all single line breaks to "soft" line breaks (which can be added by Shift+Return keys). Double line breaks remain paragraph breaks (which can be added by Return key), but empty line is removed (actually, all empty lines are removed)
procedure NormalizeLineBreaks(RVData: TCustomRVData);
var i,r,c: Integer;
    if RVData.IsParaStart(i) then
      // removing empty line
         (RVData.ItemCount>0) then
        RVData.DeleteItems(i,1);
        continue;
      // converting "Return-linebreak" to "Shift+Return-linebreak", if
      // there is no empty line before. Making sure that this conversion is
      // not applied to tables and breaks, items after them, and the very first
      // item
      if (i>0) and not RVData.GetItem(i).GetBoolValue(rvbpFullWidth) and
         (RVData.GetItemStyle(i)<>rvsListMarker) and
         not ((RVData.GetItemStyle(i-1)>=0) and (RVData.GetItemText(i-1)='')) then
        RVData.GetItem(i).BR := True;
        continue;
      // recursive table traversal
              NormalizeLineBreaks(table.Cells[r,c].GetRVData);
Modified 2007-May-31: added (RVData.GetItemStyle(i)<>rvsListMarker) check
Similar function: removing all single line breaks and empty lines.
procedure NormalizeLineBreaks2(RVData: TCustomRVData);
var i,r,c: Integer;
  for i := RVData.ItemCount-1 downto 0 do begin
    if RVData.IsParaStart(i) then begin
         (RVData.ItemCount>0) then begin
        continue;
      // Removing line break if there is no empty line before it
      // Making sure that this conversion is
     // the very first item and list marker
        RVData.GetItem(i).SameAsPrev := True;
        continue;
      if RVData.GetItemStyle(i)=rvsTable then begin
              NormalizeLineBreaks2(table.Cells[r,c].GetRVData);
It's recommended to call NormalizeRichView (RVNormalize.pas, can be found in RichViewActions) after calling this procedure.
palmeira
Post by palmeira »
I am not sure if this is a bug, but at least for some documents when I use DeleteBlankLines to delete a line, and the next paragraph has a different format (a border), the border is lost.
DeleteBlandLines assumes that document may have empty text items only as separate lines (paragraphs).
Do you generate your documents yourself?
Try calling NormalizeRichView procedure (RVNormalize.pas, included in RichViewActions) before DeleteBlandLines.
gary
Post by gary »
A small improve, Replace Paragraph Breaks with space.
var i,r,c: Integer;
	s: string;
	    if RVData.GetItemStyle(i) >= 0 then
	      s := RVData.GetItemText(i);
		  if (Length(s) > 0) then
	        RVData.SetItemText(i, ' ' + s);
	  end
    else if RVData.GetItemStyle(i)=rvsTable then begin
This function is ok, except for it does not insert a space, if a paragraph started from a non-text item, such as image.
gary
Post by gary »
A procedure to trim Leading And Trailing Spaces in paragraph.
Any suggestion is welcome.
procedure TrimLeadingAndTrailingSpaces(RVData: TCustomRVData);
  i,r,c: Integer;
  s: string;
  for i := 0 to RVData.ItemCount - 1 do
        s := TrimLeft(s);
        RVData.SetItemText(i, s);
      if (i - 1 >= 0) and (RVData.GetItemStyle(i - 1) >= 0) then
        s := RVData.GetItemText(i - 1);
        s := TrimRight(s);
        RVData.SetItemText(i - 1, s);
    if (i = RVData.ItemCount - 1) and (RVData.GetItemStyle(i) >= 0) then
      s := TrimRight(s);
            TrimLeadingAndTrailingSpaces(table.Cells[r,c].GetRVData);
gary
Post by gary »
A procedure is make these methods support apply to selection and support undo. Any suggestion is welcome.
gRVE: TRichViewEdit
RVEditor: TRichViewEdit
function GetSelectedCells(ARVE: TRichViewEdit; ARowList, AColList: TList): TRVTableItemInfo;
  ItemRichViewEdit: TCustomRichViewEdit;
  item: TCustomRVItemInfo;
  i, r, c: Integer;
  StartRow, StartCol, RowOffs, ColOffs: Integer;
  ARowList.Clear;
  AColList.Clear;
  if ARVE.GetCurrentItemEx(TRVTableItemInfo, ItemRichViewEdit, item) then
    Result := TRVTableItemInfo(item);
    if Result.GetSelectionBounds(StartRow, StartCol, RowOffs, ColOffs) then
        for r := 0 to Result.RowCount-1 do
          for c := 0 to Result.ColCount-1 do
            if (Result.Cells[r,c]<>nil) and Result.IsCellSelected(r,c) then
              ARowList.Add(Pointer(r));
              AColList.Add(Pointer(c));
  if ARowList.Count = 0 then
    Result := nil;
procedure TfM.RemoveParagraphBreaks_Click(Sender: TObject);
  i, r, c: Integer;
  RowList, ColList: TList;
  procedure ApplyChangeToSelection(ARVE: TCustomRichViewEdit)
    Stream: TMemoryStream;
      ARVE.SaveRVFToStream(Stream, True);
      Stream.Position := 0;
      gRVE.LoadRVFFromStream(Stream);
      RemoveParagraphBreaks(gRVE.RVData);
      NormalizeRichView(gRVE.RVData);
      gRVE.ClearUndo;
      gRVE.Format;
      Stream.Clear;
      gRVE.SaveRVFToStream(Stream, False);
      ARVE.InsertRVFFromStreamEd(Stream);
      Stream.Free;
  RowList := TList.Create;
  ColList := TList.Create;
    table := GetSelectedCells(RVEditor, RowList, ColList);
    if table <> nil then //Process Table->Select
      for i := 0 to RowList.Count - 1 do
        r := Integer(RowList[i]);
        c := Integer(ColList[i]);
        table.Cells[r,c].Edit;
        RVEditor.TopLevelEditor.SelectAll;
        ApplyChangeToSelection(RVEditor.TopLevelEditor);
	end
	  ApplyChangeToSelection(RVEditor);
    RowList.Free;
    ColList.Free;
gdemers_logilys
How to do Delete blank lines from a selection
Post by gdemers_logilys »
I tried the code from the first post and it does what I need but on all the RichView content.
I need to do it on the selection only.
The last post by gary contains the function that is applied to the selection.
I did not test it myself, but I hope it works and can be useful for you.
Line breaks -> paragraph breaks
Converting all line breaks (added with Shift+Enter) to paragraph breaks (added with Enter).
Undoable. If selection is not empty, the procedure is applied to the selection. Otherwise, it is applied to the whole document (if the caret is in a table cell, it is applied to the whole cell).
This procedure is not applied to selected table cells.
procedure NormalizeLineBreaksEd(rve: TCustomRichViewEdit);
var ItemNo1, Offs1, ItemNo2, Offs2: Integer;
    Whole, FR: Boolean;
  i: Integer;
  rve := rve.TopLevelEditor;
  if not rve.BeforeChange(False) then
  rve.GetSelectionBounds(ItemNo1, Offs1, ItemNo2, Offs2, True);
  Whole := (ItemNo1<0) or ((ItemNo1=ItemNo2) and (Offs1=Offs2));
  if Whole then begin
    ItemNo1 := 0;
    ItemNo2 := rve.ItemCount-1;
  rve.BeginUndoGroup(rvutPara);
  rve.SetUndoGroupMode(True);
  for i := ItemNo2 downto ItemNo1 do
    if rve.IsFromNewLine(i) then
      TRVEditRVData(rve.RVData).Do_BR(i, False, FR);
  rve.SetUndoGroupMode(False);
  rve.Change;
  rve.Reformat;
Paragraph breaks -> line breaks
The opposite procedure.
procedure MakeSoftLineBreaksEd(rve: TCustomRichViewEdit);
    Whole, FR: Boolean;
  i: Integer;
  if Whole then begin
    ItemNo1 := 0;
  if ItemNo1<1 then
    ItemNo1 := 1;
    if rve.IsParaStart(i) and (rve.GetItemStyle(i)<>rvsListMarker) and
      not rve.GetItem(i-1).GetBoolValue(rvbpFullWidth) then
       TRVEditRVData(rve.RVData).Do_BR(i, True, FR);
  rve.Change;
  rve.Reformat;
Unfortunately, TRichViewEdit does not have documented methods for converting line breaks, so these procedures use undocumented methods.
filo
Re:
Post by filo »
Sergey Tkachenko wrote: Wed Nov 02, 2005 9:19 pm Modification of DeleteBlankLines - removing blank lines only from the end of the document:
var i: Integer;
      break;
Call:
thank you for your code, works perfectly with RichViewEdit, but something is wrong with ScaleRichViewEdit in case when there are more than one blank lines at the end of the document AND caret is positioned at the end of document.
In that case I have got an error message List Index out of bounds (x) where x is number of all lines -1.
How to reproduce:
dfm:
- Empty form with SRichViewEdit component
pas:
- Implement code above
runtime:
- Type some character on the first line and 2 blank lines (or make 3 blank lines, it doesn't matter)
- Call DeleteBlankLines
Thank you for your answer.
PS: I'm using RichEdit 16.15.2, demo version
