TReportRichview and Insert* methods
apprise
Post by apprise »
We use ricvhiew to define letter templates and then generate personalized letters. Everything worked excellently until we refactored our application to multitier using datasnap technology.
Then we started getting a lot of 'Canvas' errors on server side. Searching about that topic I found that TRichviewEdit is not threadsafe and that I should use TReportRichView instead.
The main problem here is that TReportRichView is missing some important methods like:
* InsertText
* InsertItem to insert tables
* InsertRVFFromStreamEd
* InsertPageBreak
and some less important methods like:
* ApplyTextStyle (set font style to barcode)
* ApplyStyleConversion (bold, italic, underline)
* ApplyParaStyleConversion (aligment)
Is there any chance that these method will get introduced to TReportRichView?
I also included code snippet of current usage.
procedure ScanData(ARVData: TCustomRVFormattedData);
  content, replacement: string;
  replace: Boolean;
  startItemNo, startItemOffs, endItemNo, EndItemOffs: Integer;
  lStartItemNo, lStartItemOffs, lEndItemNo, lEndItemOffs: Integer;
  offs: Integer;
  rvData: TCustomRVFormattedData;
  rvData := TCustomRVFormattedData(ARVData.Edit);
  offs := rvData.GetOffsBeforeItem(0);
  rvData.SetSelectionBounds(0, offs, 0, offs); // Move to beginning
  while rvData.SearchTextR(True, False, False, False, True, False, False, RVU_GetRawUnicode(StartTag)) do
    rvData.GetSelectionBounds(startItemNo, startItemOffs, endItemNo, EndItemOffs, True);
    if not rvData.SearchTextR(True, False, False, False, True, True, False, RVU_GetRawUnicode(EndTag)) then
      raise EUnclosedFieldException.Create(_('Unclosed field: %s', [StartTag]));
    rvData.GetSelectionBounds(lStartItemNo, lStartItemOffs, lEndItemNo, lEndItemOffs, True);
    // Select tag content
    rvData.SetSelectionBounds(startItemNo, startItemOffs, lEndItemNo, lEndItemOffs);
    content := Trim(RVU_RawUnicodeToWideString(rvData.GetSelTextR(True)));
    content := Copy(content, Length(StartTag) + 1, Length(content) - Length(StartTag) - Length(EndTag));
    if content = '' then
      Continue;
    replace := True;
    replacement := '';
    OnData(FOrigTemplate, StartTag, EndTag, content, replacement, replace);
    if replace then
      FOrigTemplate.InsertText(replacement, True);
      rvData.Format(True, False);
Currently we have partially working solution to make invisible Richview with allocated hwnd, what works most of the time, but not always
FHwnd := AllocateHWnd(nil);
FRichView := TRVTemplateEdit.CreateParented(FHwnd);
FRichView.Visible := False;
FRichView.Options := FRichView.Options - [rvoFormatInvalidate];
These methods are editing methods, they will never be added to non-editing TRichView.
Also, they are not efficient for replacing fields with values - too slow.
I suggest to use one of examples from http://www.trichview.com/forums/viewtopic.php?t=8
instead of SearchText and InsertText.
They do not require editing abilities, and they are much faster.
Please do not call Format method for ppRichView.RichView, it is useless and may even crash (if a document contains tables)
apprise
Post by apprise »
These mail merge examples are very simplified.
In our system all tags are at least 2 chars and there are two kind of tags:
1) simple tags {{tag}}
2) html like tags {tag} content {/tag}
and replaced values may contain new tags.
With the first case mailmerge4 example works with modifications, but there are problems with the latter one, because starttag and endtag may exist in different items.
I can suggest to improve one of this demos yourself.
They contain the main thing: how to insert data at the specified position, all other functionality depend on the application logic.
One more topic to look at: http://www.trichview.com/forums/viewtopic.php?t=9
