I want to copy the cell-content (text with attributes) without marking to clipbord. Then I want to insert clipboard-text into a selected cell of the same / other table.
My solution is not satisfactory:
- rveTable.Select(r,c,0,0); //copies cell-borderline too
- memo.selectCurrentLine; //copies only the first line (the currentline)
What is to do to copy cell to cell (content is text with attributes or rotated text or images ....)
procedure TForm1.Zellinhaltkopieren1Click(Sender: TObject);
if (memo.GetCurrentItemEx(TRVTableItemInfo, rve, TCustomRVItemInfo(rveTable))) then begin
rveTable.GetEditedCell(rveTzeile1,rveTspalte1);
if rveTable.Cells[rveTzeile1,rveTspalte1]<>nil then rveTable.Select(rveTzeile1,rveTspalte1,0,0);
//memo.selectCurrentLine;
memo.copyDef;
rveTable.deselect;
procedure TForm1.KopiertenZellinhalteinfgen1Click(Sender: TObject);
SendMessage(ActiveControl.Handle,WM_PASTE,0,0);
Copy content of a cell to another cell of the same table
You can copy either a cell content or a cell itself.
Unfortunately, if you copy a cell, it can be inserted only as a new 1x1 table.
If you copy cell content, you copy only content, but not cell attributes (like cell color or rotation).
If selecting is ok, you can do it by:
rveTable.EditCell(r,c);
TCustomRVFormattedData(rveTable.Cell.GetRVData).SelectAll;
This method selects the whole cell content.
First, thanks for your help. But ...
Program stopps at
--> (cell) unknown identifiers (Bezeichner)
I don't find cell (only cells) in the help.
What's to do ?
Jürgen
var RVData: TCustomRVData;
memo.copyDef;
rveTable.deselect;
Program stopps at
What's to do ?
Jürgen
memo.copyDef;
rveTable.deselect;
