Import HTML code without converted special characters
Testomatico
Post by Testomatico »
I'm using the RVHTMLImporter for importing HTML code. Now, I have the problem that the code I want to import includes non-converted special characters.
For example:
<p align=center>Test & Test</p>
So, if I try to import the above code I will get a ';' at the end of the string (what's totally wrong).
Is there any option to turn this converting off?
I found the part in the code that is inserting that character but I don't want to modify the component directly.
Best regards
Testo
I uploaded a fixed version of the importer, please redownload.
Testomatico
Works like a charm! Thank you very much.
