Table in OCX
kisshexuxia
Table in OCX
Post by kisshexuxia »
When in ocx ,the keydown VK_LEFT,
VK_RIGHT,
VK_UP,
VK_DOWN, event is not respond¡£
so I set a message with KeyEvent;
function OCXKeyEvent(var Message: TMessage):boolean;
var msg: TMsg;
  result := true;
  case Message.Msg of
    WM_GETDLGCODE: begin
      Message.Result := DLGC_WANTTAB or DLGC_WANTARROWS;
    WM_CHAR: begin
      if Message.WParam = 9 then
       ActiveEditor.RichViewEdit.InsertTab;
        //ActiveEditor.InsertTab;
    WM_KEYDOWN: begin
      if Message.WParam in
        VK_LEFT,
        VK_RIGHT,
        VK_UP,
        VK_DOWN
      then begin
        SendMessage(GetFocus,WM_KEYDOWN,Message.WParam,-1);
    end
    result := false;
BUT when in table from one cell to other cell with key VK_LEFT,
VK_RIGHT,
VK_UP,
VK_DOWN, the cursor is not find or it not get Focused.
or Position the cursor on a table line¡£
In OCX it will be find.
In EXE it's ok.
[/code]
1) Upgrade to TRichView version 15
2) Compile your project with the compiler define RVNESTEDFORMS
Does the problem still exist?
kisshexuxia
Sergey Tkachenko wrote:1) Upgrade to TRichView version 15
The version must 15?
my version now 14;
Please update to the new version.
If you are already a registered user, please send me email (to richviewgmailcom) or a private message with information allowing me to find your order, and I'll send you downloading links.
We are currently working on the ActiveX version of our component (working name is TextAlly), and at least in VB.NET tabs and keys work correctly.
I am not sure how it works in browsers and other host applications yet.
kisshexuxia
Sergey Tkachenko wrote:Please update to the new version.
I download Trial Versions Last updated: August 25, 2014 (TRichView v15.0, RichViewActions v5.0, ScaleRichView v6.0.2) rvpkg.zip (59.7 MB) ¡ª TRichView for Delphi 5¨C7, 2005¨C2010 and XE (for Win32), XE2¨CXE6 (for Win32 and Win64);
FOR DELPHI XE , and build the ActiveX. the Problems still exist¡£
You need a source code to recompile the source code with RVNESTEDFORMS define.
I test my ActiveX with newer version of Delphi, unfortunately it cannot be simply recompiled in XE.
This is what I can see:
- with this define, tab and arrow keys work correctly everywhere, including tables; I tested in Internet Explorer and VB.NET (under Windows 8.1)
- without this define, tab and arrow keys do not work correctly in table cells: when pressed in a cell, the caret moves after the table, or sometimes disappears at all.
kisshexuxia
Sergey Tkachenko wrote:You need a source code to recompile the source code with RVNESTEDFORMS define.
I download rvpkg.zip with DELPHI XE
it's Just like always¡£
As I said, you need a source code to recompile the source code with RVNESTEDFORMS define.
rvpkg.zip contains precompiled units, so RVNESTEDFORMS cannot be applied.
Ok, I'll create a special version of the trial for Delphi XE for you, in the beginning of the next week.
