My question is very simple, but I don't find the solution.
1.) How I can get the width and height from a item in pixel ?
2.) Can I get the width and height for each line?
The reason how i ask.
I have a richviewedit and i would the richviewedit height and width fit on the content text.
There are more simple ways to set size of TRichViewEdit to the content, than checking width of each item.
When document is formatted, you can get its height in rv.DocumentHeight property (if document is not formatted, sizes of items are unknown).
As for width, its more difficult.. For example, if you have right-aligned paragraphs, they will be positioned at the right side, so you will not be able to determine document width by its coordinates.
This problem can be solved if you define some default document width and assign it to rve.MaxTextWidth. Text will be wrapped at this width even if rve.Width is greater. After formatting, you can get the real text width as rve.RVData.TextWidth.
Note: rve.DocumentHeight includes rve.TopMargin and rve.BottomMargin.
rve.MaxTextWidth and rve.RVData.TextWidth do not include rve.LeftMargin and rve.RightMargin.
I have similar task to solve: I read a template RTF file to TRichViewEdit. Then I have to replace some special fields by values and print it. But without setting MaxTextWidth, all center aligned items move horizontally, while resizing TRichViewEdit and the form loses proper appearance. So I need to set MaxTextWidth to value taken from template file. E.g. the template first line can be a pattern, because it is filled with graphics from left to right margin.
How can I read first line text width?
I do not completely understand your problem, but below you can find the code returning the X coordinate of the rightmost item on the first line (assuming that the direction is LTR):
You may want to add RichViewEdit1.Style.ParaStyles[RichViewEdit1.GetItemPara(0)].RightIndent.
var LastLineDItemNo, i: Integer;
LastLineDItemNo := RichViewEdit1.RVData.DrawItems.Count-1;
for i := 1 to RichViewEdit1.RVData.DrawItems.Count-1 do
if RichViewEdit1.RVData.DrawItems[i].FromNewLine then begin
LastLineDItemNo := i-1;
break;
FIRSTLINEWIDTH := RichViewEdit1.RVData.DrawItems[LastLineDItemNo].Left+RichViewEdit1.RVData.DrawItems[LastLineDItemNo].Width
