How to FIXED CELL
kisshexuxia
How to FIXED CELL
Post by kisshexuxia »
How to protect and fixed cell size.
1.Input does not wrap.
1.I am so to solve the problem
ParaInfo.Options + [rvpaoNoWrap]
2.Input is greater than the cell length tips beyond the cell length range.
I don't know how to solve.
It's possible only for the whole table, not only for some specified cell.
Include rvtoIgnoreContentWidth in table.Options.
Assign Cell.BestWidth to specify its width.
kisshexuxia
Sergey Tkachenko wrote:It's possible only for the whole table, not only for some specified cell.
THANKS I TRY TO SET BestWidth AND BestHeight .IT'S OK
table := TRVTableItemInfo.CreateEx(2, 2, RichViewEdit1.RVData);
table.Options := table.Options + [rvtoIgnoreContentWidth, rvtoIgnoreContentHeight];
  for c := 0 to table.ColCount-1 do begin
    table.Cells[r,c].BestWidth := 100;
    table.Cells[r,c].BestHeight := 100;
RichViewEdit1.InsertItem('', table);
How to judge the input text over the BestWidth or BestHeight to remind users.
What triggered the method USES .
[/code]
Sorry, the current version of TRichView does not support indication that the cell content does not fit the cell.
