Import HTML file problem
ibr_ozdemir
Post by ibr_ozdemir »
hi
When i export (html format) a text with RichView application, its working great. But when i import the same file i lose the text styles (like bold, italic, align settings).
I also tried RVHTMLImport. How can i handle that.
thanks
ivssys
Post by ivssys »
Use SaveHTMLTo...Ex() and the latest (beta) RVHTMLImport. That should work.
Regards,
Henk van Bokhorst
RvHtmlImporter does not support [arbitrary] Cascading Style Sheets (CSS).
If formatting in HTML is defined using CSS, it will be lost when importing.
In TRichView, there are two methods for HTML export. SaveHTML saves HTML without CSS, SaveHTMLEx saves with CSS.
The latest version of RvHtmlImporter understands CSS saved by SaveHTMLEx. It can be found here:
http://www.trichview.com/resources/html ... mportb.zip
