Copy and apply style button
retwas
Post by retwas »
Hi
Does the button copy/apply style exist ?
No, but I can explain how to save formatting and how to apply saved formatting.
Do you use StyleTemplates in your application?
Steku
Post by Steku »
If you don't mind, I'm interested in how to do that. StyleTemplates are used.
Thanks, steku
retwas
Post by retwas »
Yes I use, I'm interessed to know :)
I can explain how to store the current text formatting and how to apply it to selected text.
This code stores only text formatting, without paragraph formatting.
You need two variables to store formatting:
TextStyle: TFontInfo;
StyleTemplateName: TRVStyleTemplateName;
Storing:
var ST: TRVStyleTemplate;
if TextStyle=nil then
TextStyle.Assign(RVStyle1.TextStyles[RichViewEdit1.CurTextStyleNo]);
ST := RVStyle1.StyleTemplates.FindItemById(TextStyle.StyleTemplateId);
if ST<>nil then
  StyleTemplateName :=  ST.Name
  StyleTemplateName :=  '';
Applying:
if TextStyle<>nil then begin
  TextStyle.ParaStyleTemplateId := RVStyle1.TextStyles[RichViewEdit1.CurTextStyleNo]).ParaStyleTemplateId;
  ST := RVStyle1.StyleTemplates.FindItemByName(StyleTemplateName);
  if ST<>nil then
    TextStyle.StyleTemplateId := ST.Id
    TextStyle.StyleTemplateId := -1;
  RichViewEdit1.ApplyTextStyle(RVStyle1.FindTextStyle(TextStyle));
When the form is destroyed:
TextStyle.Free;
