Multi style conversion
Jim Knopf
Post by Jim Knopf »
How can I solve this problem easy:
I have to sets of styles:
style 0..4 is normal
style 5..9 are the same styles but with an other color
User marks a text that contains different styles, e.g. normal bold and italic (set 0..4) if he releases the mouse the whole marked text should be converted. E.g. 0 > 5 (normal), 1 > 6 (bold) and 2 > 7 (italic)
thank you
Martin
Jim Knopf
Post by Jim Knopf »
No hint ...?
Sorry for the delay.
Process OnRVMouseUp:
procedure TForm3.RichViewEdit1RVMouseUp(Sender: TCustomRichView;
  Button: TMouseButton; Shift: TShiftState; ItemNo, X, Y: Integer);
  if RichViewEdit1.SelectionExists then
    RichViewEdit1.ApplyStyleConversion(0);
And OnStyleConversion:
procedure TForm3.RichViewEdit1StyleConversion(Sender: TCustomRichViewEdit;
  StyleNo, UserData: Integer; AppliedToText: Boolean; var NewStyleNo: Integer);
  NewStyleNo := StyleNo;
  if StyleNo<5 then
   inc(NewStyleNo, 5);
Jim Knopf
Post by Jim Knopf »
Thank you Sergey, very helpful idea! :D
