TRichViewEdit insert table, but after insertion form no cursor¡£
For example:
TRVTableItemInfo *table = new TRVTableItemInfo(2 ,2 , rve_->RVData);
table->Color = Graphics::clNone;
table->CellBorderStyle = rvtbColor;
table->CellBorderWidth = 3;
table->CellVSpacing = -1;
table->CellHSpacing = -1;
table->BorderVSpacing = 0;
table->BorderHSpacing = 0;
table->CellBorderColor = 65535;
for (int r = 0; r<table->Rows->Count; r++)
for (int c = 0; c<table->Rows->Items[r]->Count; c++)
table->Cells[r][c]->BestWidth = 50;
bool a = rve_->InsertItem("", table);
Any ideas? Thanks.
Without cursor table
The caret is positoned to the right of the inserted table.
To move it to the first cell, add the line at the end of your code:
if (a)
table->EditCell(0,0);
Thank you for your answer, my question is no cursor click the cell, but can enter the contentSergey Tkachenko wrote:The caret is positoned to the right of the inserted table.
To move it to the first cell, add the line at the end of your code:Code: Select all
if (a) table->EditCell(0,0);
