RichViewEdit problem
hacqing
Post by hacqing »
1. convert TRVMarkerItemInfo to TRVTextItemInfo
i use the RichViewEdit controller in my application¡£
i use ctrl + c in word(*.docx 2007) file, ctrl + v to rve, rve can accept the TRVMarkerItemInfo item£¬
i use the following code convert TRVMarkerItemInfo to TRVTextItemInfo£¬but it result WideString is null
    s = "";
    this->rve->GetListMarkerInfo(i, listNo, level, startFrom, useStartFrom);
    if (listNo >= this->rve->Style->ListStyles->Count) {
        listNo = this->rve->Style->ListStyles->Count - 1;
    if (listNo >= 0) {
          listStyle = this->rve->Style->ListStyles->Items[listNo];
          if (level >= listStyle->Levels->Count) {
              level = listStyle->Levels->Count - 1;
           if (level >= 0) {
               if (listStyle->Levels->Items[level]->ListType == rvlstUnicodeBullet) {
                   s = listStyle->Levels->Items[level]->FormatStringW;
               } else {
		       //use debug, run in here
                    s = WideString(TRVMarkerItemInfo(this->rve->GetItem(i)).DisplayString);
       // result: s is ""
please tell me, how convert TRVMarkerItemInfo to TRVTextItemInfo? thanks.
2. i want iterator all items in rve and get image size:
    TCustomRVItemInfo *curItemInfo = NULL;
    for (int i=0; i< this->rve->ItemCounts; i++) {
        curItemInfo = this->rve->GetItem(i);
        printf("WxH: %dx%d.\n", curItemInfo->GetImageWidth(), curItemInfo->GetImageHeight());
out:
WxH: 0x0.
can you tell me, how to get to the item image size? thanks.
note: i use RichView 14.12.6 version.
thank you very much¡£
1) Your code seems to be correct, please send me a simple project showing the problem to richviewgmailcom
2) GetImageWidth() and GetImageHeight() return nonzero values only for items containing images and controls (rvsPicture, rvsHotpicture, rvsComponent, rvsBullet, rvsHotspot, and rvsListMarker, if list type is one of rvlstImageList, rvlstImageListCounter, rvlstPicture).
hacqing
Post by hacqing »
i want draw all item in single line, my method is as follows:
a. get all item's size in rve.
b. calc all item's max height: maxHeight
c. sum all item's width: sumWidth
d. set rvhelper's pages size
         this->rvh_->Init(this->Canvas, sumWidth);
         this->rvh_->DrawPage(1, bmp->Canvas, true, maxHeight);
e. convert bmp32 to png rgba, and save.
but, i cannot get item size, can you help me? thanks :D
Assign rvh->RichView->WordWrap = false (before calling Init()).
Call Init with a small value as Width, then get a real width as rvh->RichView->RVData->DocumentWidth + rvh->RichView->LeftMargin+rvh->RichView->RightMargin.
hacqing
Post by hacqing »
i use the following method to solve my problem:
    this->rvh_->RichView->WordWrap = false;
    this->rvh_->Init(this->Canvas, smallWidth);
    while (rvh_->FormatNextPage(Height));
    int realWidth = 0, realHeight = 0;
    realWidth = this->rvh_->RichView->RVData->DocumentWidth + this->rvh_->RichView->LeftMargin + this->rvh_->RichView->RightMargin;
    realHeight = this->rvh_->RichView->RVData->DocumentHeight + this->rvh_->RichView->BottomMargin + this->rvh_->RichView->TopMargin;
    //correct realWidth
    imageWidth = realWidth ;
    imageHeight = realHeight;
    this->rvh_->Init(this->Canvas, imageWidth);
thanks again. :P
:cry: now, i has other problem:
a. i set rvhelper's size.
b. i can get page counts.
c. i want get current item (rve item) at page number.
can you help me? :D
Sorry, I do not understand your question about "get current item (rve item) at page number."
But you may look at the methods GetPageNo() and GetFirstItemOnPage().
hacqing
Post by hacqing »
GetPageNo() is right. can you give me about TRVReportHelper.GetPageNo's example?
my code: the GetPageNo() method return -1.
     int nil = 0;
    int imageWidth = 52;
    int imageHeight = 29;
    bool ret = false;
    this->rvh_->RichView->Style = this->rvhStyle_;
    this->rvhStyle_->FontQuality = TFontQuality::fqNonAntialiased;
    this->rvh_->RichView->Color = Graphics::clNone;
    this->rvh_->RichView->LeftMargin = this->rve->LeftMargin;
    this->rvh_->RichView->TopMargin = this->rve->TopMargin;
    this->rvh_->RichView->RightMargin = this->rve->RightMargin;
    this->rvh_->RichView->BottomMargin = this->rve->BottomMargin;
    TMemoryStream* dataStream = new TMemoryStream;
    ret = this->rve->SaveRVFToStream(dataStream, false);
    if (ret == false) {
        Application->MessageBox(L"save rvf to stream is failed!", L"Error",
            MB_OK | MB_ICONSTOP);
        return;
    else {
        dataStream->Position = 0;
    this->rvh_->TransparentBackground = True;
    ret = this->rvh_->RichView->LoadRVFFromStream(dataStream);
    if (ret == false) {
        Application->MessageBox(L"Cannot Open File", L"Error",
    else {
        delete dataStream;
        dataStream = 0;
    printf("page no: %d.\n", this->rvh_->GetPageNo(this->rve->RVData, this->rve->CurItemNo, 1));
    return ;
out: page no: -1.
thanks.
For TRVReportHelper, you must pass a location in rvh->RichView.
If documents in rve and in rvh_->RichView are identical, you can call
this->rvh_->GetPageNo(this->[color=red]rvh_->RichView[/color]->RVData,
  this->rve->CurItemNo, this->rve->OffsetInCurItem)
However, it's more complicated when the caret is in a table cell.
hacqing
Post by hacqing »
this->rvh_->GetPageNo(this->rvh_->RichView->RVData,
  this->rve->CurItemNo, this->rve->OffsetInCurItem);
is right.
thank you very much! :lol: :D
