TRichView and ScaleRichView for RAD Studio XE6 is available for registered users.
A public trial will be updated when we complete a couple of new features.
TRichView for XE6 (Win32 VCL):
http://www.trichview.com/support/files/temp/XE6.ZIP
Help and demos:
http://www.trichview.com/rvfiles/richvi ... demosb.zip
RichViewActions:
http://www.trichview.com/resources/acti ... tionsb.zip
(this version is newer than the trial on the downloading page)
Help and demos:
RichViewActions:
Sergey,
Thank you. Installed, no problems. Is ScaleRichView also ready to test under XE6?
The project I'm starting needs create RTF document with multiple OLE objects (third party ActiveX - ocx), store it to a stream, save to DB via SOAP, and then read from SOAP/stream, edit and re-save. I hope I can do it with TRichView
Regards,
Jacek
Regards,
Jacek
ScaleRichView for XE6 - currently for registered users only, sorry.
While I made a TRichView trial from my working version, the working version of ScaleRichView currently contains incomplete features that make it unstable.
For OLE objects in RTF - it's not so simple.
Officially they are not supported. But if you insert components in TOLEContainer and insert TOLEContainer in TRichView, it can be saved in RTF, see http://www.trichview.com/forums/viewtopic.php?t=118
As for loading, it's more complicated. A code for loading OLE objects from RTF does exists, but it is commented, because some OLE objects worked strange after loading. Unfortunately, this code does not exists in the trial, because it does not include a source code.
