How to format the imported rtf?
starhu
Post by starhu »
I need to implement the following scenario in ScaleRichViewEdit:
1.The user opens an rvf document
2.The document can contain many TextStyles, but one of them is called "BasicStyle"
3.The user chooses a RichText file to import
4. I need to import it in the ScaleRichView (SRichViewEdit1.RichViewEdit.LoadRTF)
5.I need to format the imported text with "BasicStyle" text style.
- I don't know how to find a text style by name. The ApplyTextStyle has an Integer parameter but the order of the "BasicStyle" can vary time to time
- I also don't know how to apply the style to the imported Rtf text
Can you help me? Thank you very much in advance
StyleNo := -1;
for i := 0 to SRichViewEdit.RichViewEdit.Style.TextStyles.Count-1 do
  if SRichViewEdit.RichViewEdit.Style.TextStyles[i].StyleName = 'BasicStyle' then begin
    StyleNo := i;
starhu
Post by starhu »
Unfortunately it doesn't work for me. I sent an email with the details.
Thank you very much!
I received and answered your email.
Styles from RTF are loaded not in TextStyles/ParaStyles, but in StyleTemplates (if UseStyleTemplates=True)
starhu
Post by starhu »
The big problem is that MainForm.ActiveEditor.RichViewEdit.LoadRTF seems to delet the StyleTemplates of the document (before LoadRTF I can list them, after LoadRTF there is only the "Normal").
How can I avoid it?
Answered in email.
Briefly, the simplest way is using insertion methods instead of loading methods.
