my application exports text as rtf (only rtf at at the moment). Often the texts are novels. Novels consist of two parts: front matter and content. These two sections have to have different footers (e.g. no page numbers in first part).
1) Is there a general possibility in rtf to handle sections (for this reason)?
2) If not 1) then: Richview can export as docx or doc. Over there sections are possible. Is it possible to export sections breaks and different footers in this way?
Martin
Different Sections in one document
Sections are not supported yet.
But if the problem is only in exporting, it is possible to embed section-break code in RTF and DocX.
For RTF, an example is here:
http://www.trichview.com/forums/viewtopic.php?t=2742
If you need a similar example for DocX, let me know.
