How to prevent a user entering more text then fits the cell
Frederik
Post by Frederik »
The cells in a table must keep their originally assigned size. To prevent the cells from re-sizing when the input text exceeds the visible cell space the table.options include [rvtoIgnoreContentWidth, rvtoIgnoreContentHeight, ...].
It prevents cell re-sizing but the user can still type in more text then fits the cell. How can I prevent users from entering more text then fits the visible cell area or at least give them a warning when they do?
Is there a way to calculate the "formatted" texheight from a cell so it can be compared to the cellheight. GetItemtext methods only seem to return "raw" text strings.
thanks in advance
The only suggestion I can make is checking Cell.GetRVData.DocumentHeight in OnChange event, and calling Undo if it is too large.
Frederik
Post by Frederik »
The cell.documentheight somehow always returns 0 ... however, the documentheight of the TopLevelEditor does return the actual formatted textheight. When the input text "overfills" the cell the TopLevelEditor.DocumentHeight gets higher then the Cell.BestHeight. Bingo!
Thanks!
