I need to share a StyleTemplates with several documents. So i have a question.
I need to save StyleTemplates for all documents and Documents in rvf format. So how to save StyleTemplates to stream and how to store rvf without StyleTemplates inside it and to load rvf with external StyleTemplates?
StyleTemplates question
The current version of TRichView does not allow to store RVF with external StyleTemplates. If you do not save StyleTemplates to RVF, references to them will not be saved as well.
A solution may be in saving RVF with StyleTemplates, but applying external StyleTemplates to document after loading. I can explain how to do it, if you need.
