Rtsp
The current version of RVMedia - no.
But it will be supported in the next update (planned for very near future) using GStreamer http://gstreamer.freedesktop.org/
I have more questions
About component RVCameraMultiView
1.It possible add Event to cameras OnDubleClick
2.Procedure BringToFront;SendToBack;
3.On Play video from file it have controls ex. Stop Back Play etc...(As TmediaPlayer in FireMonkey)
About Component RVCamera
4.On save video i can in real time change the file and component begin record to new file without stoping ?
1. Ok
2. RVCamMultiView.Viewers.Viewer is a control (TRVCamView), you can use its methods.
3. Currently, there are only commands for starting playing from the beginning (PlayVideoFile) and stopping (Abort). We will add pausing and other commands in future updates.
4. Sorry, no. Changing filename affects only next writing. Currently, it's not possible to switch saving to another file seamlessly. We will implement it in future, but not right now.
I received your file, but I cannot reproduce the problem.
I used http://www.trichview.com/rvfiles/rvmedi ... ording.zip
This video file is played correctly.
Sorry, I prefer forum and email.
