Table 1px border problem with MergeCells
execoma
Post by execoma »
Hello!
IF:
TRVTableItemInfo* __fastcall CreateTable(int Rows,int Cols,TCustomRVData *RVData)
	TRVTableItemInfo *Table = new TRVTableItemInfo(Rows,Cols,RVData);
	Table->BorderStyle = rvtbColor;
	Table->CellBorderStyle = rvtbColor;
	Table->Color = Graphics::clNone;
	Table->BorderColor = clBlack;
	Table->CellBorderColor = Graphics::clNone;
	Table->BorderWidth = 1;
	Table->CellBorderWidth = 1;
	Table->VRuleWidth = 1;
	Table->HRuleWidth = 1;
	Table->CellPadding= 2;
	Table->CellVSpacing = -1;
	Table->CellHSpacing = -1;
	Table->BorderVSpacing = -1;
	Table->BorderHSpacing = -1;
	return Table;
+ MergeCells()
Result:
http://s3.hostingkartinok.com/uploads/i ... 00f501.png
If TSRichViewEdit->RichViewEdit->SaveRTF() - no problem.
If srvActionPrint1 - problem.
Please help me.
If you use old version of ScaleRichView, please upgrade to new version.
Also, try including rvtoCellBelowBorders in table->Options.
execoma
Post by execoma »
Sergey Tkachenko wrote:If you use old version of ScaleRichView, please upgrade to new version.
Version:
RVE 13.10. RVA 3.4. SRV 4.6
IF
Table->Options = Table->Options << rvtoCellBelowBorders;
Cell borders become invisible.
I install new version:
RVE 14.12.6. RVA 4.5.7. SRV 5.9.6
Another similar effect:
http://s4.hostingkartinok.com/uploads/i ... f8bcbb.png
rvtoCellBelowBorders also makes the cell borders invisible.
Please send a sample RVF file to richviewgmailcom
execoma
Post by execoma »
execoma
Post by execoma »
I'm doing everything right?
Maybe move this topic in "Private Support Forums"? (accidentally created here)
Sorry for the delay.
- Rules are deprecated feature of tables. Please do not use them, use cell borders instead.
- Please do not use clNone to hide borders, assign BorderWidth/CellBorderWidth=0 instead.
execoma
Post by execoma »
Sergey Tkachenko wrote:Sorry for the delay.
If remove Rules and clNone code lines result:
http://s7.hostingkartinok.com/uploads/i ... 8e7ebe.png
Can you give an example of code? Please
Also assign
Table->BorderVSpacing = 0;
Table->BorderHSpacing = 0;
execoma
Post by execoma »
Bad:
1. Stamens in the corner
2. Border 2px. I need 1px.
Code:
TRVTableItemInfo* __fastcall TForm1::CreateTable(int Rows,int Cols,TCustomRVData *RVData)
	Table->CellPadding      = 2;
	return Table;
Can you give full example code? Please
execoma
Post by execoma »
And:
This code creates a table with 1px lines between cells - if you set 100% zoom.
Line ends are also artifacts of zooming. We will fix it in future updates.
execoma
Post by execoma »
It is not only artifacts of zooming:
1. If I print (TsrvActionPrint):
https://www.dropbox.com/s/yn76ni4g0v87i ... %D0%B0.png
2. And I need table border 1px !!!
If set BorderWidth = 0 this is terrible:
https://www.dropbox.com/s/zefe9rqy75gnw ... B0%202.png
Russian: Я не владею английским. Может быть плохо излагаю суть проблемы. Отчеты, которые готовятся в TSRichViewEdit служат для распечатки на принтере. Отчеты состоят из множества таблиц с кучей MergeCells. И эти "артефакты" серьезно портят внешний вид документа. Если бы отчеты не распечатывались, а наблюдались бы с экрана при zoom 100%, то на это можно было бы закрыть глаза, а так не получается. Очень странно, что у столь навороченных компонентов со столь долгой историей такие странные проблемы, как создание самой простой стандартной однопиксельной таблицы. Поэтому у меня ощущение, что я просто чего-то не понимаю или плохо излагаю мысли, т.к. иначе есть ощущение некого когнитивного диссонанса.
Answered in a private message.
The line-ends problem in zoomed view is fixed in TRichView 14.15.1 (available for registered users)
